damonjackson_spl
Hi, i bought a sample of 3 x 48v 500W ecitypower hubs and 3 matching 48v 12 MOSFET controllers and 1 x 48V 10AH li-ion battery
this is the test bike, Kona Dew Deluxe disc 29er
wired them up using their new 12 MOSFET wiring diagram and works excellent!! very very powerful
PROBLEMS:
1.
8km into 1st test, battery made smoke and popped fuse, problem: excess heat had caused key lock wire to disconnect from fuse soldered terminal and earthed out, also wire gauge looks under size..
ECITYPOWER explanation - tech department agreed key lock wire is undersize and will endevour to tell the manufacturer to upgrade wire in the future
SOLUTION - I have bypassed fuse all together and have run new 8g lines with matched 40A blade fuse, works well so far!
2.
9km into 2nd ride, Motor was spinning internally but not gripping, assume clutch malfunction..
was able to jiggle and play to get it to engage again, however now making nice grinding noises under full throttle!!
1 more km and grinds to a halt (excuse pun) and retired back to workshop to pull down hub for investigation.
internal electrics melted
ECITYPOWER explanation - tech department presume hall sensor wiring put in incorrect sequence resulting in excess heat and nuking of the internal electrics, they said the motor is brand new and tech department are trying to determine the CORRECT wiring as there are several ways of putting the wires together that all make the motor work, however there is only one correct way, the others result in excess heat.
SOLUTION - still awiating
any thoughts/contributions to this test?
cheers
Damon
PROBLEMS:
1.
2.
cheers
Damon
