glennswest
- Joined
- Sep 11, 2017
- Messages
- 3
I've got the bug. Want to buld a 20Kwh design.
Looking thru the threads on welding/soldering etc, and the china tech, yes
I could build packs easy enough.
I just want something better.
Here's what Im thinking:
48V + (14S Config Pack)
Build a couple of custom pcb (I have the tools to do this, and its cheap to fab).
1. Top board has a MC33771 bms chip, and a Wemos D1 Micro NodeJS Wifi controller plus battery terminals (Spring Loaded and static pins)
2. Bottom Board has spring and static pins)
3. All batteries have a proper fuse in between (Proper automotive fuses)
4. Power and Ground are fused for max power (With proper automotive fuses)
5. Pack issolation is FET controlled for both legs - Pack is disconnected by default
6. Microcontroller and fets are controllled from separate fused path from busbar.
7. A 60V in 100ma regulator powers the bms and mcu from busbar
I will integrate the battery mount in 3d print, so whole thing is nice and smooth and looks fully commercial
No soldering or welding needed to assemble.
Pack will screw directly into drilled and tapped busbar, (Thinking brass thumb screws maybe) With large surface area.
SO mount your bus bars on wall, as much as u want.
Screw in your packs.
Bring them up and charge and balance them.
Bring them online.
Any thoughts?
I will most likely use very heavy copper for pcb's and maybe nickel on top.
Everything Opensource of course.
Anyone have feedback? Like dislikes?
Bring them online.
Any thoughts?
