Arakasy
Nice one !!! Thanks buddy
maxwell92036 said:The battery meter on the bafang display is not very accurate. Once you start showing less than 4 bars you are getting low. Once you are at one bar the display acted up on me
I have completed round trip s of 26 miles total on my 48v 750w with 10ah battery. I can't measure wh used but I started at 54 volts and ended at 47 volts. The BBS is programmed to shut off at 40 volts, so I still had quite a bit of range left.cycborg said:maxwell92036 said:The battery meter on the bafang display is not very accurate. Once you start showing less than 4 bars you are getting low. Once you are at one bar the display acted up on me
Yeah, it's frustrating that there's no way to configure the fuel gauge, or to know know how it's configured - it doesn't know what your chemistry is, or how many cells you have, all it knows is "48 V" or "36 V". I'll be installing a Cycle Analyst tonight so hopefully over the next few battery cycles I'll get a feel for the bars vs. Wh relationship for my particular battery.
Anyway, thanks for the real-world range data. Makes me feel pretty confident about my 10 Ah capacity on my 20 mi RT commute when my company moves next month.
maxwell92036 said:My third bafang mid drive bike has a 10 AMP hour battery and I know it is good for 20 to 25 miles with a fair amount of climbing. I don't like to run my batteries to shut off so If I was doing more than 20 to 25 miles regularly I would up it to a 15 AMP hour battery.
Now that I got the clutch deal squared away I am really enjoying these bikes. Super fun, climb just about anything, are fast (30 plus MPH), quiet and are well balanced. I really like not having any drives chains or belts hanging out on the main unit like some other kits. I think the Bosch, Optibike and Bafang mid drive systems will prevail for the main market where people want a clean and sealed unit. Now the big key to me is reliability, which only time will tell.
tomjasz said:One of my BBS01 350W runs at 19.5-20.1 at full throttle. The other @ 20.5-21.7 also at full throttle. Same speeds at max PAS.
boekhour said:tomjasz said:One of my BBS01 350W runs at 19.5-20.1 at full throttle. The other @ 20.5-21.7 also at full throttle. Same speeds at max PAS.
Is this with or without you pedalling?
Power to the people!t3sla said:As for the bottle battery placement, I'll let this photo do the talking.....
0utrider said:Power to the people!t3sla said:As for the bottle battery placement, I'll let this photo do the talking.....
Egards! Fried it trying to program? Thanks for that tip, but how do I avoid that? I'm making my cable, finally, this week.cycborg said:The "K" portion is the controller, which is easily swappable, which is fortunate for idiots like me who fry theirs trying to program it. :?
P+ needs to be shorted to PL to activate the controller, but if either of these then contacts TxD or RxD, the battery voltage will go straight through to the controller’s brain chip. This is easier to avoid if you’re splicing wires - I was wiring a connector instead and due to inadequate strain relief the wires pulled out their solder cups and shorted inside the connector.tomjasz said:Fried it trying to program? Thanks for that tip, but how do I avoid that?
Ah yes, the time-honored reverse-engineering tactic of feeling the bumps on the potting goo…spinningmagnets said:The question that just popped into my mind is...What is the unique identifying number(s) on the controller so we can all understand when you have an authentic 9-FET without opening up the controller and feeling the bumps on the potting goo.
In the case of of BBS01 serials I posted, it's my understanding that the controller wasn't updated. The BBS02 was upgraded. Correct? But there are two different controller numbers. Should would be nice to know what the scoop is.spinningmagnets said:Yes, the motors and controllers can be mixed and matched to sell the same handful of components in various countries with differing power limits. The question that just popped into my mind is...What is the unique identifying number(s) on the controller so we can all understand when you have an authentic 9-FET without opening up the controller and feeling the bumps on the potting goo.
Apparently there is nothing wrong with the original 6-FET, if you keep the amps under 22A and maybe even a little less if you have unusually long and steep uphills (heat)...
6 to 1? That’s nothing! How about the Indonesian Rupiah - 11701 to 1! or the Iranian Rial - 26540 to 1! Those are the people really sticking it to the North Americans!von said:The exchange rate is 6 to1
I bet you say “kW per hour” on a regular basis.$3000 yuan
If you poke around this forum a bit you may encounter a few people who like the DIY and customization aspects of the whole thing.you still need to find a bike, buy batteries and assemble it all
