tomjasz
1 GW
Check that may be just an oversite in the listings of the package.gdb415 said:Thanks Tomjasz.....However,it doesn't look like its offered for the 750w motor.
Rusty123 said:I've got a 36v 350w unit. Can I install one of the replacement controllers that Paul (and others) are selling to convert to 500w (25 amp vs 18 amp)? Or will that overload/overheat the motor?
The 750W unit appeared to be the same physical size as the 350W unit, and my experience with exaggerated China-made performance claims made me skeptical of the 750W spec. However, I have recently been informed by a North American distributor that the motor is wound to a different Kv, so when it is run at 48V, it will spin at the same output RPMs as the 36V / 350W version.
This allows the mechanical-gear RPM-reduction to remain the same for both units, and they can also share many of the same housing and interface parts. More volts can add more power without significantly adding more heat, and it is the heat that has frequently proven to be the limiting factor on these smaller motors.
However, we do not live by volts alone. The North American distributor has verified that the stator on the 750W unit is 5mm wider, which allows for a slightly greater copper mass (it is roughly one pound heavier due to the wider steel stator and extra copper wire in the coils). This means that the BBS02 motor can handle more amps than the BBS01 motor before reaching saturation. As you can imagine, I was very pleased to learn this. Both units have built-in over-temperature protection circuits that will cut power before the unit would be damaged.
Samd said:Sent some sizing to the laser cutters for a 104 BCD Chainring adapter, should make a good little commuter.
Samd said:No problem sharing the file by the way, but I expect that my cost should be about $25 per adapter set, so probably not worth firing up the laser. Should fit in domestic postage too.
Probably wouldn't be hard to craft one up on a drill press though for a DIY solution...
Samd said:Let's see what I can do.
Opened up the 250w. Easier to work on than Aprilia middrives.![]()
Nice central chassis with the motor bolting film one side, with Controller and clutch mech on the other side.
But Controller is fully potted. Wasn't expecting that.
Supplier is sending a new controller when china reopens in a week.
Original stamping blacked out. Hmmm.
FWIW I get 25 miles full throttle rides, 100kg rider with the 13.8AH EM3ev 36V. Solid 35kph over half the charge.Kepler said:If you are happy with a max speed of around 35kph, I think the 36V system is a good choice.
tomjasz said:FWIW I get 25 miles full throttle rides, 100kg rider with the 13.8AH EM3ev 36V. Solid 35kph over half the charge.Kepler said:If you are happy with a max speed of around 35kph, I think the 36V system is a good choice.
I understand that the BMS used limits the charge speed. New terms for me but both packs I have limit the charge to 3Ah(I think), chargers rated at 2.5Ah are supplied. I was disappointed but apparently no way round the issue. At least none for the uninitiated. I wish installing a CA on my system were more easier and understandable. I've a long protracted path I'm afraid.jkbrigman said:tomjasz said:FWIW I get 25 miles full throttle rides, 100kg rider with the 13.8AH EM3ev 36V. Solid 35kph over half the charge.Kepler said:If you are happy with a max speed of around 35kph, I think the 36V system is a good choice.
Tom, your comments are awesome. Makes me insanely curious what a BBS02 could do with 50v 20Ah, or a BBS01 with 36V20Ah.![]()
Remember: the cool thing about staying low-voltage and upping the Ah is that you can get a higher-speed charger and ram current into the pack faster: if each cell can only charge at 1C, then every parallel leg adds another 1C charge rate.
In the case of LiPo bricks that can charge at 1C=5A, three in parallel allow 15A charging and four allow 20A charging. If you're using power at, say, a 5 amp rate and charging 4 times faster, NOW you're talkin!
It's GREAT to me to see conversations about range and efficiency. You see it so infrequently here on the Big E-S!![]()
tomjasz said:Who is the vendor please?
