2... If anyone else experiences random turning off of the C950 display unit then please shout out! Mine has some sort of endemic fault where after about 10 minutes or so of riding you stop say at a junction or crosswalk the speedo climbs down toward zero and as it hits zero the unit switches itself off! You have to then turn it on again, re-select your assist level (always high!) and off you go again. It never turns off while riding, its not a loose wire or anything, its in the software or display or something. I have taken to never stopping, instead maintaining a crawl whenever I can to keep it alive. On the odd occasion it wont do it, making me think there is a way around it. I have tried everything I can think off to diagnose it. At one point I thought that because I had spira-wrapped all the wiring together the brake cut off switches were causing interference with the display loom and sending the turn off signal to the controller but it wasn't that. My latest theory is that when on throttle the motor thinks its not running, and that only the pas gives it the 'on' signal so when you don't pedal for a while the controller goes into shutdown readiness awaiting the wheel to stop moving and turn off or something? Its weird but it doesn't really detract from me enjoying the unit as I just work around it, but I cant fix it either :? Little help?
