Rollodo
Just curious, can this be reliably used on a fat bike, on sand?
Rollodo said:Just curious, can this be reliably used on a fat bike, on sand?
EVTodd said:So is the official pricing on these going to start at over $600?
I really want to get my hands on one but at that price point I'm not so sure. Anyone have a guesstimate on pricing once these are officially being sold in the United States?
lcrewse said:EVTodd said:So is the official pricing on these going to start at over $600?
Officially sold in the US now (ship from Arizona) http://endless-sphere.com/forums/viewtopic.php?f=31&t=50188 or http://www.lectriccycles.com. 350w and 750w in stock and already been shipping out 350w units for several months. At this point only one with the 750w actually available with kits configured specifically for the US market and a warranty.
nukezero said:On a side note, looks like bafang uses three different types of LCDs. I wonder what's the difference with the third one. The second one seems the nicest of all but I'm super concerned of theft. It's very fancy. The C950 which is what I have would appeal to less people as it shows vel, odo, dst. To someone in the US, that probably just means it is some kind of speedemeter and distance measurement screen. Probably wouldn't steal it as much as the chrome-bezel looking C961.
The C963 also seems a bit fancy with the piano black finish.
The downside to my C950 is the fixed KM/H display.
lcrewse said:nukezero said:On a side note, looks like bafang uses three different types of LCDs. I wonder what's the difference with the third one. The second one seems the nicest of all but I'm super concerned of theft. It's very fancy. The C950 which is what I have would appeal to less people as it shows vel, odo, dst. To someone in the US, that probably just means it is some kind of speedemeter and distance measurement screen. Probably wouldn't steal it as much as the chrome-bezel looking C961.
The C963 has real time power info (in watts) but also only displays in km/h and has a small but high quality screen. The C961 has the 6 hex bolts securing it and the controls onto the handlebar. Unless someone wants to remove all 6 bolts and steal a display with a proprietary plug that will work with nothing else, I think it's a non-issue. That is of course, unless someone with the same drive system but an inferior display, a bike multitool and a lack of morality happens to encounter an unattended bike with the BBS system :lol:
deffx said:Yes fits 68mm with a 33.5 constant diameter
Here is the pdf
http://www.bike-emotion.org/BAFANG%20CENTRAL%20MOTOR%20DRIVE%20SYSTEM%20-BDS01-%20Feb%2018%202013.pdf
and a little more information
http://translate.google.co.uk/translate?hl=en&sl=de&u=http://www.bike-emotion.org/Bafang%2520BBS01.htm&prev=/search%3Fq%3Dhttp://www.bike-emotion.org/Bafang%252520BBS01.htm%26hl%3Den%26biw%3D1440%26bih%3D739
both links taken from the pedelecs forum
Warren said:You have already voided your warranty by adding the motor, so it is up to you. If there is any flexing happening in the area of that hole you are asking for trouble. If you do increase the hole size, make sure the hole is smooth, with no sharp edges, or notches, round and deburred inside and out.
Was mounting the motor your intention? If yes, I'd personally make sure that the bike specs conform to that of motor's prior to purchasing.RoadWrinkle said:Bought a new Specialized rockhopper comp with a 73mm BB, want to mount this Bafang crank drive (750w), not sure it will work at all with the motor being 68mm design. Not sure if moving the chainline 5mm with spacers will screw up shifting and or cause derailing(?) Not sure I would be able to use both ring nuts supplied with the kit due to this issue, which makes me unsure about how secure the thing will sit in my BB frame with just one ring nut (why have two if one is sufficient..because one is not sufficient to hold tight(?). Any advice?
Not sure if the overall length of the cranks "axle" (whatever the hell the term is) will be to wide for comfortable pedaling. Seems like this unit will be a big hassle to install on this rockhopper. Anyone else done it on this exact bike? (2013 Rockhopper 29'er comp)
lcrewse said:RoadWrinkle said:Bought a new Specialized rockhopper comp with a 73mm BB, want to mount this Bafang crank drive (750w), not sure it will work at all with the motor being 68mm design. Not sure if moving the chainline 5mm with spacers will screw up shifting and or cause derailing(?) Not sure I would be able to use both ring nuts supplied with the kit due to this issue, which makes me unsure about how secure the thing will sit in my BB frame with just one ring nut (why have two if one is sufficient..because one is not sufficient to hold tight(?). Any advice?
73mm isn't a problem, just need the 5mm longer bolts and spacers on the non drive side and use one locking (the fatter one) instead of two. I have a Fat bike running this width right now as well as an old Full Suspension Titus that's had a 350w motor for almost 6 months with a 73mm bottom bracket, again no issues. The Q factor hasn't been a problem that I or anyone I know has complained about, even when mounted on a road bike I didn't feel it was an issue.
