Riding home tonight, noticed a bit of unusual noise coming from the drive. When I got home, I took the chain off and ran the drive up. Sure enough, the unusual noise continued and sounded worse with the chain off, almost like a grinding noise. Next I checked for play both in the cranks and in the chain ring. there was a little bit of play in the cranks but quite a bit in the chain ring. Not good.
First thing first, removed the cranks and chain guard and checked the bolts holding the chain ring on. All tight. So further investigation required. Removed the drive from the bike and and checked the locking nuts that set the tension on the thrust bearings. These were on the loose side so I tightened these up and re checked. All the play was gone from the cranks but the chain ring still continued to have significant play.
Was getting a bit worried now thinking the worst like perhaps a worn shaft or failed bearing. Removed the main gear cover and thrust locking nuts then extracted the BB shaft. This comes out with the final gear and free wheel assembly. Next I removed the PAS sensor ring which is held in place with a C clip. Finally the culprit was found. The 5 countersunk screws that hold the final gear on to the free wheel assembly were all loose. Excellent, a simple fix after all. Removed the screws and added new loctite then re assembled making sure the screws were torqued down firmly. All play was now gone.
Took the opportunity to clean the final gear and re grease. Re assembled the drive and reinstalled on to the bike followed by a quick test run. All fixed and as quiet as the first day I installed the drive. Back to being a happy camper
