treenutter
- Joined
- Aug 6, 2015
- Messages
- 17
Thanks sl33py! Those look nice. Is that some delicious organic chocolate I see in the background?
sl33py said:a bit on the spendy side, but there's also the A-Spec Nano-tech 4500mAh which is super shallow around 20mm. Nearly 6" long - 3s, so two in series should be very similar if not thinner and lighter than the older 6s thin pack mentioned.
Spec.
Capacity: 4500mAh
Voltage: 3S1P / 3 Cell / 11.1V
Discharge: 65C Constant / 130C+ Burst
Weight: 278g (including wire, plug & case)
Dimensions: 150x44x19.5mm
Balance Plug: JST-XH
Discharge Plug: 5.5mm Bullet connector
