torqueboards
Nice work. Glad to see more vacuum forming done
torqueboards said:Nice work. Glad to see more vacuum forming done.
torqueboards said:What kind of vacuum form setup are you running? What did you use for your mold?
torqueboards said:Looks great. Did you anodize it or powder coat it? Looks like you got a few mounts in the back. You should definitely try a dual diagonal setup.
drmacgyver said:Excellent looking housing! I'm thinking about making my own vacuuform at home for the same purpose. What thickness plastic did you use and what size/power shop vac do you recommend?
brent said:Did you ever run into any problems with the set screw-style mount? ie from the truck not being completely flat/accurate
gcebiker said:Gotta call it the Barney Stinson Board......Legend...ary !!!
Mad skills 8)
torqueboards said:You should try 3s 5000mah at 27mm. They also have a 6s long lipo thats 12" and 26mm in height.
treenutter said:Torquboards, where can we find the 6S Lipo you described? (12" and 26mm ?) That sounds excellent. I hunted around this post and the broader web and I still can't find it. Thx!
torqueboards said:treenutter said:Torquboards, where can we find the 6S Lipo you described? (12" and 26mm ?) That sounds excellent. I hunted around this post and the broader web and I still can't find it. Thx!
They no longer have it available I think. You can get 10S long nano cells but no longer have the 6S long lipo.
