Tommm said:I don't think 90v is the way to go, just shunt it to 60 or 70a. Afaik the 40 and the 60 are identical inside, and the 60 can be modded to 70-80.
lukashanak said:IMG_20190819_081739-756x1008.jpg
Ultralight and narrow Cyclone 4000W
11/72 gearing, so gearbox is needless.
About 2kgs less weight compared to my previous setup.
Well, you have to remember that these kits came out well over 5 years ago, the eBike landscape looked quite different then... the original kit was probably designed to be pedaled too, at about 100 RPM cadence or so... hence the planetary.Tommm said:Very good, I guess the cooling gets better too that way. I will go as far as saying this is the way the cyclones should have been sold from the start. You don't need 2 stages for this motor at all.
SwampDonkey said:So where did you find that 219 chainring and get it mounted? Really cool build!
lukashanak said:SwampDonkey said:So where did you find that 219 chainring and get it mounted? Really cool build!
I wrote it a few posts before...
Its from Cycmotor X1 pro
SwampDonkey said:lukashanak said:SwampDonkey said:So where did you find that 219 chainring and get it mounted? Really cool build!
Oh cool, good idea! I guess its either that or the Lightning Rods 219 chainring. Would it be worth building a steel version? I have access to a CNC mill, and I can design in CAD/CAM. It can be done.
lukashanak said:SwampDonkey said:lukashanak said:SwampDonkey said:So where did you find that 219 chainring and get it mounted? Really cool build!
I have Cyc X1 Pro chain version at home for my brothers bike. So when I saw it...Lighting Rods didnt respond to my email. They have adapter for standart gocart sprockets so you have more options for sprocket than 53/63/72t. But Cycmotor have smaller motor sprocket 11t. And Cycmotor sprocket have 12mm hole and my 4kW cyclone have 10mm shaft. I welded 12mm hole and make new smaller.
SwampDonkey said:lukashanak said:SwampDonkey said:lukashanak said:I wrote it a few posts before...
I gotta steal your idea lol. Just looks bad ass and is probably more efficient after getting rid of that big planetary gearbox.
lukashanak said:SwampDonkey said:lukashanak said:SwampDonkey said:Oh cool, good idea! I guess its either that or the Lightning Rods 219 chainring. Would it be worth building a steel version? I have access to a CNC mill, and I can design in CAD/CAM. It can be done.
It looks nice compact and I can use narrower BB. Cyclone 4kw have 178mm ISIS and now I have 148mm BB from cycmotor.
I ordered 72T, 11T, 219h chain and BB all from cycmotor. 143USD with shipping to CZ.
SwampDonkey said:lukashanak said:SwampDonkey said:lukashanak said:I have Cyc X1 Pro chain version at home for my brothers bike. So when I saw it...Lighting Rods didnt respond to my email. They have adapter for standart gocart sprockets so you have more options for sprocket than 53/63/72t. But Cycmotor have smaller motor sprocket 11t. And Cycmotor sprocket have 12mm hole and my 4kW cyclone have 10mm shaft. I welded 12mm hole and make new smaller.
How are the motor shaft bearings holding up? I know they're smaller than the ones on the original 20mm output shaft. I wonder if replacing them with ceramics or other high performance bearings would be a good idea. The LR single stage "big block" kit is somewhat similar.
Grantmac said:How is the noise without the planetary? Could you pedal at low power if you wanted?
Tommm said:Grantmac said:How is the noise without the planetary? Could you pedal at low power if you wanted?
No, you would cook the motor putting any meaningful power down, say going above 30kph and sharing the work with the motor. You can pedal, but the motor would be resting. :lol:
gman1971 said:Its made out of carbon fiber, aluminum tubes and lightweight pvc with coroplast. It has pretty much all the amenities of a car, keyless entry, illuminated approach, push-to-start button, accent interior lighting, VHF/UHF digital DMR radio, HUD with GPS and heated seat!!
adam333 said:gman1971 said:Its made out of carbon fiber, aluminum tubes and lightweight pvc with coroplast. It has pretty much all the amenities of a car, keyless entry, illuminated approach, push-to-start button, accent interior lighting, VHF/UHF digital DMR radio, HUD with GPS and heated seat!!
wow! you sure put a lot of work on this build Gman
Gratz! it is a nice achievement.
SwampDonkey said:Tommm said:Grantmac said:How is the noise without the planetary? Could you pedal at low power if you wanted?
How would you cook the motor? That c4k motor barely gets warm at 6kw.
gman1971 said:Wassup folks, long time no post... I see there is the ruthless pursuit of powa going on... pretty cool... 150 amps! How is the chain holding?insane power.
So, last year around March, after the winter subsided I realized I couldn't endure/fare another Wisconsin winter riding A-1, a full open cockpit trike just isn't meant to ride when temps hit -10F. Sure, you push through bundled up, etc, but you realize that no amount of clothing keeps you warm at 40mph, plus the salt was very hard on the exposed mechanics, etc... The point was that I needed something different... so I set out to build a new trike, codenamed: YA-3... I spent most of spring last year prototyping it in 3D Studio, testing ergonomics, etc. Here is how the 3D prototype looked like.
It took me the whole summer just to build it... and around mid-September last year it was ready for road trials. After a few controlled tests and some dry runs it looked very promising so I made the decision to phase out my A-1 trike, which at that time had ~10k miles on it. What I didn't realize tho, is that rushing YA-3 to full commuter duty proved to be the wrong decision. To put it in nice words: it had a lot of teething problems, lots of firsts on YA-3, so lots of bugs to work out and winter quickly approaching, by November it was cold enough outside I couldn't do much, so unfortunately I ended up spending most of the winter patching it up left and right just to keep it running (from falling apart), it wan't fun if you ask me; but at the beginning of summer this year I put A-1 back in commuter service for a couple of weeks and set out to fix all the problems I faced in YA-3... and now, its finally ready for prime time.
Introducing my latest Cyclone powered e-Trike: A-3, right next to the trike it replaced, the veteran with around 11k miles A-1B
The large glass cockpit was the hardest thing to do, I wanted the pedals, and me pedaling it to be very visible to everyone on the road; and that was the #1 design priority: build a trike around a glass cockpit so I could load it up with an unspecified amount of kilo-watts and never raise a flag. As of today it has 1738 miles GPS confirmed.
I have to say , its truly a blast to ride... feels like you're inside a fighter jet, and I also have a small shell that I can use to cover the top (but my helmet remains outside) for winter and when it rains... no more getting wet when driving in the rain... no more freezing my tail off when temps drop to -10F, and no more rusted everything in salt... and then, to put it in simple terms, it blows the doors off A-1 on every test we've thrown at it.
G.
Skaiwerd said:Does this go here?
Referring to the above post
