le15otl said:
G yeah the cassette hub it just wobbles a bit. Not sure if it can be replaced on it's own. :/
Bob no reason that will be a problem if it fits in the gap!
Hmmm, wobbles side to side? Perhaps the splined locking nut needs to be tightened a bit? I've seen it wobble on my ebike and was due to the cassette lockring being lose... you could always check that; you can always add a washer to the lockring so it puts increased pressure on the 1st cog thus preventing the wobble.
Also, worth mentioning that it was suggested (don't remember where) using a ziptie to hold the cassette to the spokes of the wheel so the freewheel won't freewheel when you let go the gas (since you have already the crank freewheel anyways) thus being able to shift at speed without having to pedal... not sure if this is related, just throwing some ideas.
Tightening the lockring/nut is worth a try.
I've also found that different hubs makes do make a noticeable difference in terms of construction and "wobbliness"; I still have the cheap 1st cassette rear wheel (no disc) that I used on my first GNG ebike and that one isn't as tight to begin with as the Shimano Deore hub I have now on the same (now Cyclone) eBike, the difference is noticeable in terms of smoothness and the splines/grooves are larger on the Deore hub.
G.
