gman1971 said:ebike11 said:Chalo said:ebike11 said:is there a particular name for those nut cyclinders and tool?
They're chainring nuts, and a widely available version of the tool is Park CNW-2.
Yes i searched chainnuts but only see short ones. For the cyclone 3 chainring set..the chainribg nuts are quite long
I would contact Paco at Cyclone to get more of those... or where you can find those... if they keep coming lose, use a generous drop of blue loctite on them. I wouldn't use red as red is probably too strong and you might ruin the the keyed side with the screwdriver trying to pry it open
G
Yeah ill make an order soon for a few things.
I also damaged my chain guard..i think i wont put another on coz the chain sometimes got jammed solid tight between the guard and chainring. Then again it was my fault for misalignment.
Where do you put your temperature wire from the Cycle analyst Gman?
