Been on a marathon build streak to try to get this done before a bike trip to the coast. Came down to the wire but it's running now and it's Great!! Still got lots of little details and fettiling to do but it's running good and solid. Here it is?
Here is the inverted disk modification I did with the disk on the inside of the disk adapter rather than on the outside a spacer between the disk and the motor cover was necessary to clear the bolt heads. The caliper was about .5mm from the hub at that point and I had to put one extra washer between the caliper and the adapter to get the caliper high enough to give the 2mm of clearance you can see here.
You can also see the the aluminum spacer between the brake mounts and the adapter that allowed alignment after the swing-arm widening modification. The brakes are very solid, responsive, and more than strong enough to lock em up easily on asphalt. Here is the three speed freewheel. The chain clears fine but I am still trying to find an adjustment that will prevent the arm from touching the hub cover when it is on the top cog.
Here is the "dash board" arrangement. Still need to figure out how to connect the cruise control unit, this controller did not have a wire for it like my last one. The plug on the end of the cruise control unit that I got from Lyen has some weird multi-plug arrangement that I don't understand.
As for the modified swing-arm, I could not be happier. The actual drop-out width is 155mm the Kiwi TA eats up 5mm so the actual width is 150mm WITH the TA and I would say that this just about perfect. Everything fit nicely. I laced my own rear wheel. A fact that I am inordinately proud of. It is on a 26" sun double wide rim and I am using WTB Wierwolf 2.5 tires for now. Got the spoke length pretty close for my first try. After tensioning it up I had to add 4mm of dish to get the tire dead center. This picture shows the side-to-side symmetry.
The picture makes it look like the tires are touching on the sides but here is a different angle showing the clearance.
Lots of room! With this much clearance I could easily fit a 3.5" tire (if one existed for bicycle rims).
I went 40mph right out of the box after setting up the CA V3. It does not have scary low end torque yet but it's only drawing 38 amps from a dead stop on level ground so I suspect that the controller needs to be flashed. Any recommendations for controller settings? My arrangement is 18s2p 16Ah, V2 Cromotor, 18 fet Lyen controller with double beefed traces, 26" wheels and a CA V3. How important do you all think it is to upgrade to the latest version of the CA firmware? I'm sitting at v22 now. I guess I'm going to have to get a cable from Grin. Still have to do some sheet metal work to get the rear battery box panel to fit properly and figure out how to cover up the wire bundle at the front of the controller and...oh....several dozen other things. Only been on quick little test rides and then had to go to work for two days straight. Taking it up to Mendocino coast for a few day starting tomorrow though so I'll get to see how it does on longer rides. Obiwan
