Lebowski
Did you use the CA with my controller ? What does the CA do to the throttle signal ? All these test are on the MAC ? How many phase amps max ?
yes. should do nothing as it's "pass through". yes. max 210*.7=150ALebowski said:Did you use the CA with my controller ? What does the CA do to the throttle signal ? All these test are on the MAC ? How many phase amps max ?
thanks. so this is equivalent to "our" hall sensors which give the throttle position. correct?SplinterOz said:I can help with at least one of the questions.
TPS is throttle position sensor, very common term in automotive circles, not that common on ebikes.
i'm happy to do it. i like kelly controllers from the first time you recommended them to me. and i still like my "old" trapezoid controller. now with the sine-wave types they turned silent, which is very much welcome.crossbreak said:nice case mod. think i will just mill down the fins on the bottom. i wanna use it with up to 120A so that's half of what it's meant for. thanks for being the guinea big and all of those nice pics![]()
izeman said:thanks. so this is equivalent to "our" hall sensors which give the throttle position. correct?SplinterOz said:I can help with at least one of the questions.
so this sentence "(6) TPS Low Err: Hall active pedal, if lower than the value, report the fault of TPS Type, Range:
0~20" would translate into "(6) TPS Low Err: Throttle low voltage error. If throttle voltage is below that value report an error. Range 0-20% of 5V"
i was interested to know this as well... maybe this has something to do with my strange full speed rpm issue?!riba2233 said:I have one question about these controllers, do they offer field weakening? I don't see anything particular in manual, except for max rpm setting. So, if my motor can do 3000 rpm on 48 V, and I set max rpm in controller to 5000 rpm, do you think that it would apply field weakening? Thanks![]()
izeman said:i was interested to know this as well... maybe this has something to do with my strange full speed rpm issue?!riba2233 said:I have one question about these controllers, do they offer field weakening? I don't see anything particular in manual, except for max rpm setting. So, if my motor can do 3000 rpm on 48 V, and I set max rpm in controller to 5000 rpm, do you think that it would apply field weakening? Thanks![]()
how would you do that? my no-load speed sits at 2000rpm. if i go zero rpm to full rpm instantly i see rpms of around 2300. this settles to 2000rpm after some seconds. 2000rpm sounds reasonable rpm for 48v and the 8T mac. but i can't say how much it should be exactly. i could install the old kelly and measure speed and compare.riba2233 said:Maybe it would be the best to do no-load test with two controller settings, one with "natural" rpm setting, where no field weakening is expected, and then one with rpm set to 150% of "natural" no load speed.
if the motor works well with trapezoid controller, shouldn't it work also well with FOC or at least it should be possible to adjust timing settings to make it work well.Lebowski said:Maybe it is again the oversaturating of the motor ?
i agree with you madin88. and if lebowski's thoughts would be right the problem should disappear at 500W power input, but they don't. the motor/controller behaves the samemadin88 said:if the motor works well with trapezoid controller, shouldn't it work also well with FOC or at least it should be possible to adjust timing settings to make it work well.Lebowski said:Maybe it is again the oversaturating of the motor ?
Im not absolutely sure, but i have in mind that the MAC works well together with the Adaptto. i once read a bit in a russia thread.
thinking about it, that's a VERY good idea to look at. i will order some genuine honeywell SS-41 and replace the ebay ones that are installed. any suggestions on even BETTER hall sensors to use?madin88 said:may it be that there is a problem with the hall sensors? like that they are to slow in response or something else..
facebook denier hereSplinterOz said:So this is the Colossus outrunner motor with the KSL-D 400amp
https://www.facebook.com/tony.castley/p ... tif_t=like
izeman said:facebook denier hereSplinterOz said:So this is the Colossus outrunner motor with the KSL-D 400amp
https://www.facebook.com/tony.castley/p ... tif_t=likedo you have this somewhere else?
