Oscillator
- Joined
- May 3, 2019
- Messages
- 15
After reaching out to Ebikeling they confirmed that there shouldn't be an issue running their 36v conversion kit on 48v, it was mentioned that I would need the appropriate display though. With that information I ended up purchasing a 36v 12.5ah battery on Amazon from Yose Power, it was very affordable, a possible gamble but I figured if it didn't work out I can always return it. The kit and battery got here a lot sooner than anticipated, the Ebikeling kit got here 2 days early and the battery only took 2 days to receive, very impressed and am glad to be able to get a jump on the build.
Before installing the kit on the bike I wanted to bench test all the components to ensure that they operate to avoid wasting time in case something did not work. Unfortunately, this seems to be the case. I've connected the essentials, the display, throttle, controller, motor and battery, whenever I operate the throttle I can hear a minor little click from the motor but there is no operation whatsoever. I've tried playing around with the different speeds and giving the motor a helpful nudge with no avail. I don't know if there is something I'm missing, the brake levers and PAS are listed as optional and do not need to be connected according to their installation info. I'm wondering if maybe I received a faulty component, I'll reach out to Ebikeling and see what they say and in the meantime see if I can't troubleshoot this, cheers :thumb:
Edit: After going over my connections I found that the extension cable from motor to controller did not look like it was seated well. Disconnecting and reconnecting remedied the issue, so stoked! I'll report back once the kit is installed
