John in CR
100 TW
I converted one of my Nexus 3 geared hubs with coaster brake to add a 203mm disc rotor.
Here's what I started with.
I removed the torque arm for the coaster and drilled 9 holes in the spoke flange for the bolts. At a greater radius than normal disc rotor attachments and nine 3mm bolts instead of the normal 6, I think the bolts will hold up. I thought 18 would weaken the flange too much.
Then I fabricated an adapter that leaves space for the spokes, and for simplicity I just welded the rotor to the adapter. The housing on the hub doesn't spin, so the adapter fits over it without touching. That housing is a larger diameter than the standard bolt pattern, so normal attachment of the disc was out. I was originally planning to bolt the disk on, so due to material thickness and space constraints, the holes in the adapter are threaded and don't go all the way through.
