minde28383
- Joined
- Apr 2, 2010
- Messages
- 702
Yesterday I bought Giant NRS XL 22.5" frame for my new e-bike project. Looks like this is 2004 model, though I found no sticker with years on it. Frame itself has no cracks or bends except some scratches which are seen on pics.
One of bearing is worn out, because some movement is easily noticeable when shaking rear shock (see pic with red note). Some other bearing (probably pivot) is also slightly cracking though can't find yet which one exactly. I was trying to find bearing kit online though no results. Also most probably that original Air shock will need change because it holds no air-pressure and makes noise like it would crack every time when fully compressed. It would be better to rebuild original shock with rebuild seal kit then to change to new one but found no Giant Air shock seal kit on Giant online store.
I'm transferring from HT to FS frame because I expect smoother rides on uneven pavements in the city.
Plan is equip the frame with: 2806 rear hub, 26" wheels 2.2 tires, 72V, 25Amps Infineon, front fork Spinner 300.
