Hello. I've got a frame I'm trying to use for an ebike that has a broken/stuck spindle in the bottom bracket I cannot get out. THIS is a similar looking spindle. Where the red arrow is pointing is completely gone. All of it, 360 degrees. There is no where for me to get a grip on it at all. I was able to get the spindle itself out leaving it hollow, so I took a Sawzall through the hole to it to try and split the collar in half so I could eventually pry it out. I was hardly putting a dent in it. Would a carbon tipped blade work? I also tried using a bi-metal hole saw which worked a bit, but again the blade wore very quickly.
Am I tackling this the right way? Seeing as its threaded inside I don't know how else to get it out. I'm not worried about shredding the collar as I need it completely out anyway.
Thanks
Thanks
