atom1025 said:
I've test ridden at least a dozen bikes since the last post. I even tested out some off the shelf ebikes like the A2B and the stromer. Stromer was way better then a2b but they were weak and had little punch.
I found a shop about 30 miles away that stocked the Yuba Mundo and I gave it a spin. Out of all the different styles I rode I felt extremely comfortable and relaxed on the behemoth. 55 pounds stock but it rides very light. Has a cruiser stance to it. Comes complete with fenders and disc brakes for $1200. Compare that to the big dummys price tag including shipping and I save nearly a grand. They even had a Mundo set up with bionx that I test rode. I was actually impressed with the kit after hearing mostly negatives about it. Its perfect for the wife but a little weak for me.
So I am now 100% confident that a long cargo bike is suited to me. I really am not crazy over the look of the Mundo but I don't hate it either. The one size fits most idea seems lame but it fit me well at 6'3". I still want a big dummy as the comparison reviews between the two has the big d appearing much better in all departments except load capacity. The big d is ten pounds lighter and is said to feel faster.
After a week of searching it seems the best way to get a big d is to buy the frame and build it up. I think this is a good way to go as I won't waste money on parts I won't use. I've never built up a bike and I am nervous it won't come out professional. I have been purchasing tools over the past few weeks to work on stuff my self. I have a cassette tool and crank arm remover, chain tool etc.
There's a site that has frames on clearance for $175 below msrp. So $775 plus shipping. Just sucks knowing that the complete setup will be worth nearly 3gs. I don't see how I could ever leave this outside a grocery store locked up without panicking about it getting stolen.
As far as ordering by frame size. I am 6'3" and according to the charts a 22" frame would be my size. I am nervous to commit without a test feel. Some of the 22s I rode felt huge and others did not. So any advice here? 20" or 22".
Adam
Ps I have to decide on power plant leaning towards a geared Mac in the rim but running a stokemonkey style is still intriguing. Though keeping the triangles clean and open would be a nice change.
What is most important to you? Torque off the line (acceleration) or top speed? How often do you plan on having some form of cargo paniers on it?
With a cargo bike, you can go relatively fast, but unless you want to have serious high voltage and over-built (think motorcycle class or close to it) components and the price tag to match, you're going to be riding what is more of a "truck" than a sports car.
I would concentrate on acceleration and low end power personally since sometimes you will be hauling weight, and you might be surprised how exhilarating it is to have a heavy laden bike and even to be going a little faster than an average bicycle up a hill that normally would kill you with the heavy load.
If you will have cargo bags like the Xtracycle Hoodie, there will be less of a cluttered triangle area, however, if you are going to not go with some bags, that would seem to defeat the purpose of having a cargo bike of this kind.
I really like the design of the Hoodie bags since they collapse and expand to accommodate cargo, or are pretty streamlined when empty.
And at $40 that seems like a steal!
Don't be too intimidated at the thought of building up a bike, find someone who can give you real world ideas on what makes the most sense for your planed use, and don't try to go too cheap, in the long run, I learned the hard way in some cases that a "regular" or "bargain" component generally means you will buying a new one quicker than the high end stuff.
Most of the problems with most bicycles used in the US, is they are for recreation, and not built for every-day use, but you also might look and see what Surly has on their bike to get an idea of what you should shoot for component wise.
One thing that I never would have realized on my own, is that the standard square shank cranks with normal sized bottom bracket bearings will wear out once a season with any regular riding with just LEG POWER alone, and a friend of mine who had done this before me (and is also considerably heavier than me) had discovered this because of the monster hill here, and in the end I bought a set of used FSA cranks with a compact MTB gearing range much like this one:
So I would have the option of crawling gears if I ever had a motor side failure (22T granny gear) I could still get up the hill even with a heavy load on leg power alone.
That and a good hand built wheel are two things I will never go with-out no matter what bike I build (unless it's a seldom ridden "sunny day" bike) because I am hard on bike components, and in the end, the $80 used cranks saved me a ton! ( I have yet to have to replace even a bearing, and if I had bought a standard BB, I would have replaced the entire crank assembly 2x by now!) The over-sized bearings fit a standard BB, just have cups that allow them to fit into the standard frame and use much larger bearings that go on the outside of the BB.
Since you are building a cargo bike, if in doubt, go big and heavy duty.
I used to have several "normal" standard bicycle wheels on my bikes, most were machine built, and had to be regularly trued, and I paid the money, got some hand built wheels, and I have close to 1,500 miles on them with not even ONE truing require much less anything else, mind you I'm not as heavy as a friend of mine who used to have trouble with wheels not holding up to heavy touring bike loads, but I had myself (180/bs) and 150lbs of pedal powered touring bike (full self supported camp/touring, food, tent etc.) so 330lbs on a 26inch rear wheel that took probably 70% of the weight on my recument, and never had a problem even after hitting a 3 inch high "curb" that I didn't see till the last minute at about 20 mph, and later 25 mph in the dark in a construction zone, a 4 inch curb, hit so hard it launched the waterbottles on the sides of my seat bag straight up, and not a scratch! 8)
