Bush mechanic
⚡ Regular
- Joined
- Oct 19, 2014
- Messages
- 106
Hi crew, would love to get some thoughts on this: Shengyi sx2 rear geared hub (5:1, 72 effective pole pairs), runs beautifully once at speed, but shudders and is super rough and weak on take off. As per title, I have a v6 PR.
The most obvious potential issue I can think of is phase and hall combinations error due to my splicing of an L1019 cable (PR) to Z910 cable (this is what the Shengyi uses) - I’ve based this on wire colour alone, however, I’m tentatively ruling this out as a problem because the system DOES run well once it gets moving.
Would any of the following observations suggest any issues?
-static test, spinning test are fine, returns valid hall pattern
-oddly the motor unit did spin backwards in the initial test, fixed this by using the flip option but I’ve not had this happen before
-hall sensors seem to fire in normal sequence when I slowly spin the wheel backwards when looking at the PR suite dashboard
-currently set to hall sensors only, not sensor less
-I’ve realised the torque up ramp is very short (50ms). I did use this controller on a GMAC a few years ago, I don’t recall changing the setting but it might be a left over from that
I’ll try a few more combinations later when I get home, but if anyone has had similar issues with the Shengyi + PRv6, or thoughts on possible causes that would be awesome.
