hekdude said:Maybe you can flip it like the attached picture. It will be pushing, not pulling on the arm, but at least it is going in a better alignment. The ampedbikes torque arm you can rotate 180 degrees so you can position it for the best alignment. I did have to take apart the wiring connector since it had clearance issues with the derailleur.
I have electrified my catrike and use it for a 20 mile commute. I have speed issues with the 20" wheel, with an ampedbikes 36V lithium battery, and am dreaming about increasing my speed via extra voltage. You shouldn't be having those problems.
When I lived in Michigan, I ended up having rust issues after riding my bike in the snow/salt. (I had an EZ-Tad with a steel frame) Something to think about. In Southern California I don't have to worry about that any more.
I'm more concerned about torque issues than speed with the 2806 motor and 700c wheel @ about 48ish volts of LIPO.
On the rust issues - I'll be giving this trike a good coat of wax before I complete it (if not a new powdercoat - I HATE red bikes, but the price is always right!) The winters here in Boise ID are fairly mild, and the they use sand, not salt for icy days.
Considering the Torque arms - does the axle really end up spinning backward from the forward direction of the bike, or is that only during regen? Also - on the ebike kit one - that is not a pivot point once it is tightened properly. So it might make for a funky curve, but with that thick bolt and nylock nut, it's not going to pivot separately from the second arm.
