Alan B
Interesting design. A relay or switch with a couple of different caps would give some control for more than one current level.
Farfle said:V2 of this guy has been built. Goes in a a 240v outlet, outputs 55a @ 100v and weighs 4 pounds![]()
. 16 min charge on a 1330 wh/hr pack
I found a 5KW TVS...does that count?fechter said:Anybody seen a 5kW zener diode?
fechter said:I think a more practical approach would be to place a large solid state relay in series with the AC line and use a small control circuit to turn the relay off when the output voltage exceeds a preset value. A circuit to do this is fairly simple. It could simply latch off when the limit is reached and start with a manual push button.
The voltage will adjust. For reaching the 30Amps, you might need a 500 µF AC capacitor or different lower capacity pieces put in parallel. To rectify that current you can use the bridge rectifier mentioned in my first message.IBScootn said:Very nice. I want a 240V outlet, 28-30Adc version; what parts did you use?
Goal is a quick opportunity pack charge to 85V. For awhile I was pondering getting a 4:1 step down transformer to convert the 240Vac to 60Vac; then rectify it to 84.8Vdc; bingo - perfect bulk charger. But they want two arms and a leg for these transformers and too heavy.
fivari said:Hy Fechter, could you help me with that circuit? I have no idea how to build one. A scheme and wiring plan would be nice.
fivari said:Thanks Fechter, I already bought the LM431 and TPS2812 components to build one.
dnmun said:oh details, details.
this got me thinking of my first science project when i was about 14, back in 1960. back then they wanted everybody to become a scientist so we could beat the russians to the moon. even before gingrich decided to go to the moon.
anyway, ramjets were big in all the popular science magazines so i decided i would build a ramjet for a science project, using the gas bunsen burner in the lab for the fuel source. i found a length of downspout to make the "cylinder" of my ramjet, and put the bunsen burner underneath with the tube pointing to the ceiling of the lab. no pretesting so the ignition source i rigged up from a 12V doorbell transformer with the 120V wall source applied to the 12V windings and the high side, the 120V but now really 1200V, was inside this cylinder with a big spark gap to achieve ignition so my ramjet would work.
so i went in early and was setting it up on the bench, turned on the gas and tried for along time to get the ramjet to ignite, but the igniter would never make a spark. so it never got lit.
i still remember how dejected i felt that i had failed to get my project to work, the ramjet cylinder never ever lit in spite of my pushing tons of natural gas from the bunsen burner through the cylinder into the room for about 15 minutes before i gave up.
this is back when we had floor to ceiling windows, overlooking the schoolyard where everybody was coming to school that day.
i coulda been famous. failure sometimes has been a blessing.
bearing said:If we neglect ESR of the cap, we have the RC constant of the output cap and internal resistance of the battery pack to smoothen the current. The cap will only make a noticeable difference if the RC time is as long as the distance between the pulses from the rectifier, or longer. Pulses come at 100-120 Hz, or about 0.01seconds apart. If battery IR is 0.01 ohm, then the cap needs to be about 1F. If battery IR is 0.1 ohm, then cap needs to be about 0.1F. Thats pretty big caps, especially if they need to be rated 400V.
I think I'll make mine without output caps.
As long as the peak of the current pulses aren't far above the maximum charge rate of the battery, I don't think it's a problem to omit the output caps.
