Introducing myself as new to electric bikes and new to this forum..... but eager to learn!! I wonder if anybody can answer what I suspect are basic technical questions? I have just bought a secondhand Powabyke Euro which has 5 gears and runs off 3 x 12v/14Ah SLA batteries (now new), all this raw power :lol: to help me with the 9 mile commute to and from work (UK - combination of flat & hilly), the bike is standard..... and a little slow!!
Q1. I have read on the forum that the controller may have a looping wire connected that if removed increases my motor?controller? output from 250w to 500w. Is this correct and is there any benefit of doing this on a standard build? Does this mean the controller supplies greater amps to the motor? (my confusion probably comes from lack of understanding)
Q2. Again the forum suggests that 48v means increased speed, a guy called Bernie White at http://www.g4hjw.metahusky.net/ (powabyke electrical link at bottom of page) suggests this may take the speed up to 17.2 mph. Will my current controller take the 48v, do I need to vent the hub to reduce heat?
Q3. Other forum talk suggests a controller change to 36 - 48v deliverying 20amps, again I assume
this will drive the hub a little harder but also drain the batteries faster. Can new controllers be linked to the crank and wheel sensors on a Powabyke?
Thanks in advance
Thanks in advance
