Hi guys
What would be the best way (simplest) to add a precharge resistor to my battery-to-controller Anderson connectors for a Kelly controller??
I do not use a key switch at all. I prefer manually connecting the Anderson connector from the controller side to the Anderson on the battery side and manually disconnecting as well. Both leads are near the handlebars so thats what I like to do.
The controller is a KLS high power/voltage Kelly
Thanks a lot!!!
Thanks a lot!!!
