puchwudi said:@louis raijmakers:The chain works great without any troubles.. I also forgot about the chain line, i was SL concentrated on the wings Thanks
@riba2233: Why arent you happy with the tires? I like them.. Mine are called sawa sport... Descirbe what you dont like, maybe i have used them for a too short time
@sean9002: Thanks a lot! if you want to buy some just contact me They are just for protection ; )
You have sava MC11 right? They seem good at first, but after some more serious riding you figure out that they aren't. And also they are useless in wet conditions, you have to be really careful, especially if the road is bad.
Now, I'm sorry but I must make two more notes.
You had frame that is made for mid mounted motor, and you didn't use that option but went hub motor road instead? Don't get mad but that's an epic fail.. Aslo, headway batteries are weak, extremely heavy and big, and too expensive. They are really bad choice in 2015, and they wont be able to feed your big hub motor. Also, hub motor is heavy, and batteries are heavy, so your bike will be heavy, have non optimal handling and large mass. With mid motor and modern batteries you would save big deal of mass and get proper level of power and capacity from battery. Just a note
