Apartunis
Regular
I have made an multi layer activated charcoal hepa filter to suck all my solder or welding flux fumes/smoke.
The usual Florida way is to vent to ambient with no protection for workers. So yay?
Texas, same.
My soldering welding station used to be in garage, but being Florida with a South facing door and west facing cinderblock wall radiating stored heat internally, and a hot car engine radiating heat well after sun down means sweating balls and swatting mosquitoes a majority of the year.The usual Florida way is to vent to ambient with no protection for workers. So yay?
Texas, same.
Interesting results.Looked at the waveforms of my AWithZ UF20B on an oscilloscope. The Intermittent setting (1-20ms, 1ms increment), does increase the delay between the Preheating (0-50ms, 5ms increment) and the first welding pulse. With Intermittent set @1ms, the delay is 120ms, with intermittent @20ms delay is 140ms.
My UF20B has Number of Continuous Spot Welding of 2 (@sternwake I think your P20B has 3?).
With Preheating set to 0ms, I see only one welding pulse on the scope but hear 2 beeps. With preheating set to anything other than 0ms, I see 2 welding pulses and hear 2 beeps. Preheating settings between 5ms to 50ms does not seem to change the timing of the 2 pulses.
Gear setting vary the duty cycle, thus the power:
Gear 1 pulse width 1.25ms 6V
Gear 10 pulse width 7ms 6V
Gear 50 pulse width 32ms 6V
Gear 99 pulse width 60ms 6V
Duration of 1st and 2nd pulse is the same.
I was not aware of this setting. Just found it, it was set to 0.1 seconds. I will look at it later with the scope and see what it does.I have the "interval of continuous spot welding' set at 0.2 seconds.
With 0.00ms preheating, doing a weld instead of the 22 ohm resistor load, I heard 2 beeps and saw 2 pulses on the scope. So the results with 22 ohm load was not valid, at least for 0.00ms preheating.My scope tests were done with a 22 ohm resistor as a load across the probe tips, not doing actual welds. I will see if I can set the scope up again while doing actual welds and see if the behavior with 0.00ms preheating changes.
There are too many settings on the AWithZ IMO which makes it more complicated than necessary. Doesn't help the manual does not explain clearly what the settings do.I have not even found much difference between a single weld pulse and dual weld pulses on the same gear setting.
It kind of seems like a single pulse at say gear 400 hits harder than each individual pulses at gear 400 when set to 2 pulses.
My p20b is capable of 3 pulses and I have used triple pulse when trying to find upper limits welding 0.3+mm copper, but again I cannot definitively say that 3 pulses are doing what 2 or 1 at the same gear cannot.
Pretty sure Zeus-FL used gear 700 on the P90C to weld 0.2mm copper to those same cells, with flux but without the SS sandwich in his video.This morning I tried again on my AWithZ UF20B maxed out on gear 99. Took a video this time.
0.1mm 304 SS over 0.2mm Cu + flux over the infamously hard to weld 32135 LFP cell with a 1.6 mm thick copper tab. It was a weak weld but a weld nevertheless.
AWithZ P20B is not powerful enough per tests done by @sternwake. Maybe higher power welders such as P30 and higher will work? Won't know till someone try it.
Yep. The main trick about the P60F vs P90C is that the P90C has a much beefier PCB. The larger supercaps also make a different, but not by that much.Pretty sure Zeus-FL used gear 700 on the P90C to weld 0.2mm copper to those same cells, with flux but without the SS sandwich in his video.
Ill GUESS that would be require gear 550 with stainless on top.
The p90C is rated at 56.8kw
55% of 56.8kw is 31.24kw
The AwZ p30c is only 24kw.
The AwZ p60f is 29.4kw
There's is no awz welder between the 60f and the 90c, and the 90c is a 650$ spot welder.
I've not tried to open( pry off rectangular sidecap?) up my p20B and have a look inside.Yep. The main trick about the P60F vs P90C is that the P90C has a much beefier PCB. The larger supercaps also make a different, but not by that much.
Otherwise, it's not that different from the P60F, which is why it's a much better bargain.
If I'm not wrong, the P60F uses a 3S2P array of 1000F supercaps, the P90C uses a 3S array of 3000F supercaps and a stronger PCB, and the P120D uses a 4S array of 3000F supercaps with an even stronger set of MOSFETs and components.I've not tried to open( pry off rectangular sidecap?) up my p20B and have a look inside.
I have thought about having a 10mm wide 12v fan attached to the side, and a filtered intake opposite
The temp gauge rises pretty quickly when I am doing a lot of welds at higher power levels.
P90C 56.8 kw, P60F 29.2 kw. P90C has 48% more power than P60C. Why do you say it's not that different?Yep. The main trick about the P60F vs P90C is that the P90C has a much beefier PCB. The larger supercaps also make a different, but not by that much.
Specifically because the main difference seems to be down to them not speccing out the more capable PCB on the P60F to not encroach on the P90C. I'd love to know about the difference in supercap specs to see if the P90C truly has 94% more power available, or is part of the upselling reliant on just the PCB differnces.P90C 56.8 kw, P60F 29.2 kw. P90C has 48% more power than P60C. Why do you say it's not that different?
You are right!Also, it's not 48% more power, it's 94% more power.
Source?Specifically because the main difference seems to be down to them not speccing out the more capable PCB on the P60F to not encroach on the P90C.
| P120D | 69.2 kw | 10.5 v | 10.3 lb | |
| P90C | 56.8 kw | 10.5 v | 6.6 lbs | |
| P60F | 29.2 kw | 9 v | 3.6 lbs | |
| P30C | 24 kw | 9 v | 3.6 lbs | |
| P20B | 14.6 kw | 9 v | 3.13 lbs | |
| UF20B | 10.5 kw | 6 v | 2.76 lbs |
Oh no, I'm not talking about the differences in build. It's obvious that the P90C is bigger, beefier and uses larger caps. I'm just saying that if the P60F had the larger beefier PCB and components of the P90C, that the difference wouldn't be as large as 94%.You are right!
Source?
Not sure if this table is 100% accurate. Feel free to correct if you see any errors. Looking at the data, P60F and P30C are the two that seem to be not very different from each other, not P90C and P60F.
P120D 69.2 kw 10.5 v 10.3 lb P90C 56.8 kw 10.5 v 6.6 lbs P60F 29.2 kw 9 v 3.6 lbs P30C 24 kw 9 v 3.6 lbs P20B 14.6 kw 9 v 3.13 lbs UF20B 10.5 kw 6 v 2.76 lbs
Since I've been building some larger packs, I've figured out a pretty good setup and work flow for spot welding cells:I've been doing test welds using the same 40 18650 cells that's been Dremel-stoned a few times. The Ni plating long gone, the steel is thinner so the welds are not representative of a new cell anymore. I need to find more virgin 18650/21700 cells to practice on.
Threaded terminals will make life a lot easier. When I was looking for cells to build my moped battery, nothing else would fit and fill the battery box and provide the V and Ah needed as well as the Gotian 32135's.
Dug out my old Tektronix scope from storage to have a look at the waveforms of my AWithZ. Some results are not what I expected. I'll write about it tomorrow.
Can you be more specific please? Which column(s) and which model(s) is wrong? I believe the kw and V columns are correct since they were gleaned from published sales ads. Weight was not found for all models in sales ads. Some were obtained via Google AI search.I think this table is wrong
