The amount of downward pressure on electrodes, and the tip shape, play a pretty big role, and make any comparisons as to the 'gear' level required for User A compared to user B, difficult.
When the welder has an excess of power then more downward pressure is not going to risk the weld not welding, but with the underpowered welders using too much pressure can lead to inconsistent weaker welds.
When I got my P20B I did not have a lot of test cells, and the cells I did have were quickly dremelled free of their nickel plating, which affects all subsequent welds.
I used a razor knife blade, the trapezoidal shaped ones, and started out low and increased gears by 25 until the welds started sticking. Only one weld sticks at first, and one can see the result on the underside of the blade.
Keep increasing gear until both welds are the same size on top and below.
The Bells and whistles like double and triple pulses, preheating and the 'intermittent' the delay between preheating and the first weld pulse are distractions at this stage.
Set it to single pulse, No preheating, and worry only about the Gear.
When you get both welds to look the same size and shape on both sides of the razor blade, then try those settings on an actual cell. If the welds are strong, tearing the strips of copper/ nickel, then one might be able to use less power. Go down in increments of 20 of the 999 gear welders until one weld is obviously much better than the other and then go back up.
Be mindful to use the same downward pressure each practice weld, equal on both electrodes too. if you are resting your elbows on the table, always rest your elbows on the table.
Once you narrowed in on the gear needed, then one can play with preheating and intermittent double/ triple pulse and interval, see if they can lower the gear further and still get strong welds.
The electrode tips will get progressively wider and flatter and this changes the power required. more power is needed as they get fatter, but if one is holding them on a wide V, then those sharp corners of the tips can concentrate the force into a smaller area.
I try and hold my electrodes as close to vertical as I can get them and hold them a consistent distance apart every time. I do this for attempting to achieve consistency rather than any perceived result.
With enough consistency and practice, one can feel how hard the welder is hitting during the pulse(s) and how the electrodes slightly sink into the strips.
After a certain number of welds it starts feeling a bit different and then I clean and shape the tips. I've been using an Arkansas sharpening stone, dry and will take it to the sink and wash it when it turns copper colored.
If one punctures the copper completely, then there is a chance of Steel welding itself to the electrode tip.
If this steel is not removed then one might think their welder has broken as it might not even register.
Even the red diamond file struggled with removing the steel when this happened to me.
This primarily happened on a weird 18650 can when I was trying to weld 0.2mm copper no sandwich and no flux and blew a hole right through the copper and into the cell.
I am really well dialed in on 0.2mm copper now, using 0.1mm stainless and flux. Gear 385 double pulse, 0.15ms preheating, 04ms 'intermittent', and 0.2 seconds interval( between weld pulses) AwithZ p20B welder,14.6kw.
Note that this interval setting is not on the main menu page where it should be, in my opinion.
I always use the pedal to trigger, and am very deliberate with the motion. Stab and quick release.
There have been reports of extra unintended weld pulses, and I have experienced a few myself, but am 90% sure my foot was still half way on the pedal. There was no negative consequence to the weld when this occurred, but maybe there would be on different thickness materials. I don't know.
Just be very deliberate with the pedal if using in in manual mode.
