vicens
as Vito I do not answer.
Send a Message by ali. have if I receive answer.
vicens said:Vito Hu need help
I've this:
1.E-scooter. tire 3.50x10 "
2. current engine power 1500w
3. vehicle weight 80kg. load weight 120-140kg.
4. 58.4V 55Ah lithium battery. inr18650-29e cells. 16s20p settings
5. Maximum speed 46kmh. mode controller 120%.
6. Controller 12 fets 60V 58A.
7. I would like to go to a top speed of 60 or 70kmh.
The speed on hills could be a little more.
Road speed is insufficient. The cars ahead of you. sometimes they do not leave room. it is dangerous.
What maximum speed can be achieved with engines 2000 and 3000W?
I have less than 5% of hills on the way. the hills are small and short. How is more efficiente? maximum speed mode 100 or 120%
What idle speed is available? which one do you recommend?
If there is not much difference in price I prefer the motor 3000w v3.
My E-scooter:
https://endless-sphere.com/forums/viewtopic.php?f=10&t=80231&p=1182685#p1182685
Cowardlyduck said:I would like to see a 40mm wide motor similar to the Crystalyte HS40 motor's, but with lower weight...i.e. less than 7.5Kg if possible.
Cheers
QSMOTOR said:Dear All,
We are going to develop 205 E-bike Hub Motor, 135mm dropouts (more than 205 28H).
Do you have any suggestion on the magnet height, power, speed, voltage, suitable freewheels?
madin88 said:QSMOTOR said:Dear All,
Are you going to use V2 "EXPORT" or V3 "EXTRA" stator?
I personally would vote for a version with 35 or 40mm magnets.
As already mentioned it would be great if QS motor would also focus on reducing the weight.
Any plans for that?
For instance the weight could be reduced alot when using a separate steel ring (for magnet return only) which is mounted or pressed into an aluminum spoke flange which is than again fix coupled with the sidecovers. Also the magnets don't need to be sticked side by side. There can be a gap between which also means lower weight.
I really like the design of the bionx motors. IMO thats quite the optimum design for a direct drive hub motor:
galderdi said:I love the concept. Really great work.
Does open source mean the body shape is also open source?
If so how do you plan to share the body shape with others?
\/ampa said:That would be fantastic!
With a 5KG 40mm magnet motor you could install 2 of them on a ebike and have more power and more reliability than with just 1 11KG cromotor....
Maybe let your Engineers make a model for 20mm DH bicycle forks additionaly.
robohead said:Loving my QS205/V3 with an Adaptto Max-E controller.
Vito you'll recall I did ask some time back for a 35mm motor with V2 stator or better. I would still think many of us would want it.QSMOTOR said:Dear All,
Btw., I have updated the page of "QS 205 50H V3 Motor, Most Powerful Direct Drive Hub Motor".
Refer to the link, https://endless-sphere.com/forums/viewtopic.php?f=31&t=65972&p=1082427#p1082427
Best Regards
Which settings are you after? There are literally few dozen options in the settings.litespeed said:What are your setting exactly?
I might order a 205 for my old bomber soon as well. Would be nice if shipped by default FF coated like this.bigbore said:Yesterday I have added 5ml of ferrofluid at my QS205 30X4T and this is the thermal conductive paste I used to seal the side covers.
Samd said:Vito you'll recall I did ask some time back for a 35mm motor with V2 stator or better. I would still think many of us would want it.QSMOTOR said:Dear All,
Best Regards
bigbore said:robohead said:Loving my QS205/V3 with an Adaptto Max-E controller.
+1!![]()
Then at the sunset I went for a test ride on the beach in deep sand and the first impression is that stuff worksbecause I reached the same distance as I rode before with a lower motor temperature
This night I will try it on flat road at full throttle with OVS = 3° at about 8,5KW and see what I have holding 80-85 Km/h for about 4Km
These are my current settings:
