True FOC requires exact knowledge of the position of the rotor, hall sensors is not enough since the position is known only six times per electric revolution. Most controllers that call themselves FOC are actually a simulated sinewave so the output is sine shaped but the field oriented control is not done.
An example of true FOC is the VESC where there is a sensorless position algorithm that’s accurate enough and a processor powerful enough to do FOC (if parameters are set correctly :wink: )
There’s a bit higher efficiency with FOC, but simulated sinewave is good enough for most applications.
So FOC doesn't need the motor sensors connected?
and how does it learn the position with no sensors?
BEMF or inductance measurement, there are other methods also
and if most sine waves out there are not really sine, then what would be the difference from true sine?
Google Field Oriented Control / FOC. What’s called Sine (‘sinus’) is the shape of the phase current output so actually “sine” or “sinewave” has nothing to do with FOC
they are already super quiet, so it seems that the benefit of true sine is also in the non true sine?
See above, efficiency, torque
Which controller brand is true sine?
it’s not called true sine but FOC. VESC, i think sevcon controllers are another example
and how do you know if it's true or not?
if it’s cheap, it’s not FOC.
If you don’t need to input motor parameters like phase resistance and inductance then it’s not FOC as the FOC calculations are dependent on these
About power...
I feel an 80A Greentime controller so much stronger than a 150A Sabvoton open all the way.
i’m digging in the memory here..It’s probably because many of the infineon type controllers (greentime) have poor phase current control so you get high phase currents no matter what you set, and phase current is what matters for torque. Never owned a sabvoton so cannot say anything about it.
Is 80A phase or battery current..
The alibaba controller hasn’t even got phase current setting specified for the three levels, makes me think it will be a hard onset, poor control output. You’d probably directly want to have better throttle control just like the when using infineons
btw, the one in the link I posted is not by Yuyangking, it's by a different brand called Yuma.
