HardWaterATX
🔌 New-ish
Bought this bike second hand to add to the e-bike lending library that we are building for charity work. I knew that it didn’t work but since it came with two batteries and all of the extras I took the chance for $650, the fella said that he thought it was an issue with the controller. Wouldn’t turn on so I replaced the display at which point it fired right up. But now with interesting malfunction, it will speed down the road just fine on either PAS or throttle but the moment you stop giving it juice it will motor brake and throw an error 21 and won’t let you throttle again until it has come to a complete stop.
Their website lists the error as electrical so I replaced the controller as I bought one with the display just in case. No dice, and it’s only now that I’m thinking what I should have thought from the get go with a geared motor that isn’t freewheeling and shouldn’t be capable of motor braking. Is it possible that the clutch has failed and now when it’s not under power it is essentially turning itself into a generator which then sends current to a controller that is definitely not expecting that and throws the error? And if so is there even a fix for this that doesn’t involve replacing the motor which you can’t even get from the partially defunct Radpower company?
I’m not against opening up the motor even though I’ve never repaired a hub motor in this way before. Our org has a very limited budget so anything that can get me out of buying a whole new motor and having it laced into the rim is preferable.
I have combed ES as well as Reddit and my best googling and have not run into this issue anywhere else.
