liveforphysics
100 TW
Jeremy Harris said:As I mentioned previously, both of the Prius BLDC motors run immersed in light oil and this doesn't seem to increase losses to an appreciable degree, or else I'm sure Toyota would have come up with a different way of doing it, as they were intent on making the system as efficient as possible.
I think an experiment is called for here, because we're speculating about viscous and swirl losses that may not be as great as we think they are. I have a spare 5330 motor that's already fitted with long leads. I'll have a go at running it no-load in a bucket of light oil tomorrow and see what happens. IIRC I have some 10W-30 synthetic oil around somewhere, probably a bit too thick for the job, but at least it'll give us a data point. The only snag with this test is that the motor is a low Kv wind (around 88) so I won't be able to wind it up to a massive rpm.
Jeremy
Right on Jeremy!
If you could measure the no-load power at say 3-4 different RPM points, we could get a pretty good idea of the nature of the drag function.
You mention the Prius tranny/motor having oil in it. On the dyno with a normal automotive transmission, we see around a 10% power loss in a FWD car's tranny, and you can distinctly see the linear component of the loss function (gear surface friction) taxing you roughly a flat-rate tax on your torque, and a second component which increases at the square of RPM, which is the fluid drag component from having the bottom side of the gears dragging through the oil in the sump (windage loss). It starts out with only gear-face friction being noticed, and then the fluid drag overcomes it at higher RPMs.
This is why some modern race transmissions and rear-ends actually dry-sump the oiling now, so the fluid level sits below the bottom of the gears, and a little pump sprays oil to the critical locations, and just avoiding this fluid drag is worth some time in the quarter mile. It's become the standard for NHRA prostock now, and cars that don't do it generally can't be competitive (due to everything else in the class being almost identical, and first and last place being separated by about 0.05s.)
