Arlo,
Yes, I understand about the the flux control of the can on the outrunners. The original hope was to be able to run hall sensors reliably from the outside, but the best laid plans oft gang aglay. :wink: the internal mounting is more work, but dead reliable.
That particular wind will require about 170 volts to realise maximum power output.
but will be cold running work horse on 48V with reasonable reduction to drive a bike crank.
All my bench testing shows these motors really don't like to spin above 9500-RPMs. There is a huge spike in the heat generated at that point I can only assume is Iron loss/core loss. Doesn't seem to matter the wind...
For those thinking about winding motors it is really not too difficult. but here is how it goes.
single wire=easy
double wire= 3 times as difficult.
triple wire=5 times as much trouble (& prolly a neglagable gain in performance at this scale, just use bigger wire)
(I get to frustraighted to attempt any more than that....the larger the motor the more forgiving it is also)
Danny-one of these evenings I'll organise the 3-speed drawing & detail it & dxf-it to you. Right now its a series of concept sketching that prolly only would make sense to me. (its also all in 2D but I bet you could fix that LOL) It really was intended for a larger motor (or maybe multiple motors
