deronmoped
- Joined
- Oct 6, 2008
- Messages
- 706
My Gaint LaFree bike thru a commutator segment from running the 24 volt motor at over 50 volts. Too much heat and too many RPM's was probably the reason the segment came loose. I'm thinking some epoxy and dental floss might work. Dental floss would be used to wrap the commutator and epoxy would be used glue the segment. I will test the floss to see how much heat it can tolerate. Any other ideas to secure the segment. Stainless steel wire would work good, but it conducts, so something as strong and thin would be ideal.
