made_in_the_alps_legacy
Regular
in the meantime, a petrol station would allow you to inflate them kick and high (maybe too high)
How is your Chinglish lesson going ?
daverobson08 said:Pediglide - I hadn't even realised that! Now that I look at it, there is definitely a difference. Thanks for thatI think the tyres definitely need properly inflating. They seem to be difficult to fill up with a bicycle pump. I might invest in a digital compressor or just a foot pump.
Pediglide said:Although...I'm not sure about them risers. You effectively lessen the leverage force of your board by putting on a narrower riser. You will feel a lot more squish side-to-side but it will not translate to turning.
I'd rather fancy a riser that is the same size/area as the octagon shaped top of the truck. The harder the material, the better. Or you could just remove them since you said the motor gets a bit too close.
Yeah, apparently if you charge an 8s fully the ESC will be in "safety mode". Anyway I just use it with 7s and I'm very happy with this ESC. I read somewhere that it shouldn't be used with just one motor but if torque didn't run into problems it should be fine right? I think for our application those are the best, mainly because of the flat construction and the abstinence of cooling fans.daverobson08 said:Alien 8s is 7s? I don't understand
...said in other words :superpef said:mainly because of the flat construction and the abstinence of cooling fans.
Hm yeah, I'd still prefer the alien ones. I think they are still thinner and the wires don't attach from the top..made_in_the_alps_legacy said:you can remove the cooling fan of 150A+ car ESC
...not sure what you mean, i used this esc in the first version of my e-skate... (see in my built thread) it's now on my e-scooter, i have a spare one which might end up on a ebike, it works fine, i never got it warm, and not that expensive..daverobson08 said:I've decided to take a gamble on a Heli ESC (I'm hoping I can prove you wrong made_in_the_alps! :wink: ). I bought this:
