LolRodney64 said:. Even the paddy wagon had a second look.
No I haven't which is the issue. 12s and 24s bulk chargers only. I will look at getting a photo today. Current setup is what is recommended for my weight and the frame currently it has the 450lb spring.pendragon8000 said:LolRodney64 said:. Even the paddy wagon had a second look.
No doubt.
They look great.
Both on 18s sounds good. You have a 18s bulk charger?
Can you get a side on photo of you on the bike with the suspension taking your weight?
I'm interested to see how how it sits with a rider on it. Its hard to tell if its a big frame or not because its sort of unusual dimensions. Do you think it could be setup more firm in the rear and a bit lower?
Cheers
At the moment only 60k on 18s. I need a 3 speed switch. Im thinking that this controller at the moment is only running at 70% and I need to install one. May try this when I get home from work.Rix said:Nice Rod, its always good to get out for a ride. 18S with a 4080, that will be quick, say 75-80 KPH.
I was going to comment on that from your video, you'll chew the powdercoat off in the first ride without addressing that. A tensioner on the swing arm might be of use too.Rodney64 said:Planning on putting a piece of plastic stip above the chain to protect the swing arm from chain slap.
Allex said:Rodney, the coils and BMSs are ready in the end of next week. After that you can bulk charge your 18s all day long =)
Rix said:Yah Rod, that's not right 60KPH on 18s, I am getting 65KPH on 14s.
Hyena said:I was going to comment on that from your video, you'll chew the powdercoat off in the first ride without addressing that. A tensioner on the swing arm might be of use too.Rodney64 said:Planning on putting a piece of plastic stip above the chain to protect the swing arm from chain slap.
Looks like the seat on the phasor is all the way at the back too! Do you prefer to ride more stretched out or do you have long-ish arms ? Maybe look into a laid back seat post as well so there's not too much leverage on the back of the seat ?
The bike looks like a pit bike with the little wheels. No issue with pedal strike ?
No that's ok. What colour frame did you get. I've copied off others so that's ok. I went shimano as its easy to get parts here in Perth.Jonboy said:Hi Rod, bike is looking great.. I can't wait for mine to land!! I opted for a zee crank N nukeproof headset.. Sorry to copy I just couldn't deal with a headset mine field & the zee is great value! I gave into bling in the end & went Hope tech3 v4 for brakes![]()
From when you sent the Money how long did you have to wait?
Cheers & keep us posted
Jonboy
Rodney64 said:No that's ok. What colour frame did you get. I've copied off others so that's ok. I went shimano as its easy to get parts here in Perth.Jonboy said:Hi Rod, bike is looking great.. I can't wait for mine to land!! I opted for a zee crank N nukeproof headset.. Sorry to copy I just couldn't deal with a headset mine field & the zee is great value! I gave into bling in the end & went Hope tech3 v4 for brakes![]()
Jonboy
I've just received my new throttle today Its a different type of thumb throttle and it looks good. The plan is to fit it on the weekend with some rapid fire leavers for the rear 7 speed freewheel.
http://www.aliexpress.com/snapshot/6201997962.html
Jonboy said:Rodney64 said:No that's ok. What colour frame did you get. I've copied off others so that's ok. I went shimano as its easy to get parts here in Perth.Jonboy said:Hi Rod, bike is looking great.. I can't wait for mine to land!! I opted for a zee crank N nukeproof headset.. Sorry to copy I just couldn't deal with a headset mine field & the zee is great value! I gave into bling in the end & went Hope tech3 v4 for brakes![]()
Jonboy
Rod the Qulbix site shows the 140 with frame white and black swing arm, How is your swingarm white?? special order? then it's just stickers to make the colour..
I went white on white option 20 in 20 in the gallery... Figuring it'd look ok.. black swing arm with my new black Boxxers at the front 8)
I had news that mines back from the paint shop & will be shipped tomorrow![]()
What rear Mech you running Rod & what size is your smallest rear sprocket?
Cheers
Jon
I was looking at those just the other day Rod! They look better than the usual thumb throttles and may fit on the bars a bit better with the other accessories. Do they actually have a carbon fibre finish ?Rodney64 said:I've just received my new throttle today Its a different type of thumb throttle and it looks good. The plan is to fit it on the weekend with some rapid fire leavers for the rear 7 speed freewheel.
Yes standard is white frame, black swing arm and black side covers with your choice of stickers.Jonboy said:Rod the Qulbix site shows the 140 with frame white and black swing arm, How is your swingarm white?? special order? then it's just stickers to make the colour..
bachomp said:Sweet build !
Now I am even more excited and can't wait for my frame and electronics to get here !
Hyena said:Sorry I just supplied the frame and motor. Be sure an remove the sticker if you hooked it up to a controller that delivers more than a 2.7A @ 72v :lol:
Rodney64 said:No off riding yet Rick but Chris commented on it's turning and that it didnt want to turn. Similar to understeer. When chris Mentioned this to me I did say that I could lower the forks in the front so the stearing would be more direct. But I know absolutely nothing about setups.
Is this what you were talking about Rick. (jonescg) would be the one to talk to about handling with his race bike experience and he rode it yesterday and he did make the comment that he loved it and I'm not sure if that was the handling or the look.
Rodney64 said:bachomp said:Sweet build !
bachomp welcome to the forum. What state are you from. Good to see more Raptor builds here down under.
