kiltedcelt
Established
So, I was having issues with the shifter on the NuVinci N171 that I'm using on my recumbent tandem trike build. The e-assist is Bafang BBSHD so the choices for geared hub were Rohloff or N171. I bought the N171 because it's WAY cheaper, but the cables are SO LONG that the drag (with or without full housing), is causing them to kink inside the shifter housing and I've already ruined two shifter cables. So, I said "EFF IT!" and pulled the trigger on a Rohloff hub. I guess, consider it a longterm investment as it should outlive several projects. Anyway, on the N171 I was installing one of those in-line Bafang motor cutoff switches that kills power when it senses movement of the shift cable. The problem is, the shift cable runs THROUGH that switch and inside is a tiny wheel that actually introduces some drag into a system (long-ass shifter cables) that already has a crap-ton of drag to begin with. The Rohloff shifter is WAY better designed than the very crude 1.0 version of the NuVinci shifter, and I've been doing a LOT of reading about Rohloff in the last few days. It seems that it can handle shifting under load, as the worse that happens is that it defaults momentarily to I think 14th gear when loaded but as soon as the torque lightens up it drops into the proper gear. It's apparently NOT like an Alfine where parts will actually break inside the hub when shifted under load.
The trike has an independent pedaling system where the stoker can pedal while the captain coasts, and the way the BBSHD works, this means that even if the captain is coasting, the stoker can still be forcing the BBSHD to apply power, unless the captain instructs them to stop pedaling during shifts OR a motor kill switch is employed to cut motor power under shifting. Of course this still doesn't change the fact that while a cut-off removes motor power, the stoker could still force the hub to be shifting under load. I am thinking that maybe I just avoid the B.S. of cutoff switches and it just becomes understood that the stoker stops pedaling when the captain calls out "SHIFTING!" or maybe "GEARS!" since in the right circumstances, "SHIFTING!" could maybe be mistaken for something else.
The other thing complicating this decision is that Rohloff recommends (and ships the hub), with what is essentially spiral wound brake cable housing as the shifter housing, and they recommend with the newer hubs full housing from shifter to hub. Although, I saw on the Co-Motion YouTube channel them installing a Rohloff and having only housing coming out of the shifter and going into the hub. The longer stretch on the downtube had the shifter cables exposed and cable stops were used. So, I'm thinking if I use even partial housing but use the brake cable housing, then it won't go into a Bafang cutoff switch anyway, not to mention I don't really like how that switch puts noticeable drag on the actual shift cable running through it. The other thing is I read about a one-button cutoff switch that you press when shifting, or using a brake cutoff switch and tapping your brakes momentarily while performing a shift. Both of those situations seem kind of janky. So, I guess - is a cutoff switch really needed - especially if I can also go into the BBSHD program and limit it's make power output and thus it's torque? Also, the low-tech solution of telling the stoker to stop pedaling? Of course that won't always work and it's entirely possible powered shifts will eventually be forced through the Rohloff due to miscommunication. Basically I don't want to blow up a $1600 hub that would have to be sent back to Germany to be repaired.
