The panels are flexible, but not intended to be rolled up and carried a lot. Bending them a lot will kill the cells.
Price for that type is ok, but you might find cheaper, depending on time of year. Like a lot of stuff, buy it in December for better price.
While not as good as hard panels, less efficient and less lifespan, they have advantages in some uses. They are very light, so good for carrying around on a bike trailer. And they bend to fit a curved surface. I have three of these 100w panels on my camp trailer, that has a curved roof like a boat. They don't stick up and create drag while I'm towing, like some rigs I've seen on school buses. I'm sure its costing me more per watt hour in the long haul, but saving me mpg in the short haul.
The panels I have put out 18v (12v panels) but you could get close to 72v with four of them in series. Ideally, a charge controller for 60v would go with that. 5 panels and 72v charge controller for 72v. Your panels won't put out full voltage when its dim, so you need headroom on the voltage, then a charge controller or at least a converter to get to your packs charging voltage.
Another approach would of course, to convert 18v up to a higher voltage, but its most efficient to keep that voltage conversion to a low number. two panels in series (36v) can convert to 57v fairly easy, to slightly under charge a 52v system.
Looking for 24v panels would help of course. They put out up to 30v.
