rossfree
I cleaned up some wiring a bit and got the new brakes on the bike. Temperature hit the 50's (F) over the weekend. Wierd! Had to get the bike out. The shifter needs some work but I was able to get it into a higher gear so I could pedal a bit with the throttle open.
Got salt-water all over everything! Ha! Lucky I got back at all! Have to put some priority on protection from the elements.
I found my new avatar! Can you guess which picture???
I am very pleased with this trailer connection arrangement. I feel no side loading on the back wheel. I don't take sharp corners with the throttle open... so that's no big deal. But I do accellerate through reasonable curves without concern. This is not what I would consider an off-road bike. The smoother the roads the better. Trailer bounce is not significant but it's there when the road gets bumpy. Three lines of traction means you don't miss many bumps. And I stay away from pot-holes. The wet, icy, sandy roads makes biking precarious at best. I can't really "dodge and weave" to get the full feel of the trailer behind the bike. When the sand and ice go away and the roads dry up I'll be experimenting more. But I LIKE IT!
Rear View: (4) 12v 19amphr AGM batteries from Walmart... note the 30amp automotive fuse in series with the pack. The fuse sits in the recess of the batteries so I can put a flat top across the trailer. Once I mount the controller and charger below, the whole top will be flat (except for the screws and washers mounting the motor).
The tape in the other battery recess hides a spare fuse! 8)
I built a utility trailer several years back. My Dad told me to you never have enough places to tie things down with ropes or bungees. So by his suggestion, I put 12 or 14 welded loops around the bottom perimeter of the utility trailer and love them. The loops are bent down so that you could hook a length of rope around it. Or you could connect bungee hooks or strap hooks to it. I'll be doing something similar with this trailer for tieing things to it. I won't need quite as many. :wink:
When I remount the trailer tongue, the trailer will be parallel to the ground (no tilt).
The beer came from a buddy down the street. Those wire thingies come in handy!
Here's some more pictures:
Ross
Ross
