werner32
100 µW
- Joined
- Sep 5, 2013
- Messages
- 7
Below is the specs.
Wired up the battery but would not work. Took off the blade and motor and selfporpelled drive works great.
Issue was BMS would detect a short I think with the blade on so I bypassed the BMS and vola..
Mower now works great.
My issue is now without the BMS bypassed how will I avoid over charging?
Maybe leaving BMS attached to charger all the time until charging is needed...
1X Lifepo4 Battery (48V 10AH)
1X 6A Quick Charger
1X BMS
Specifications:
Voltage: 48 Volts
Lifecycle: >1000 times
Capacity: 10 Amp Hours
Dimension: 195x150x100mm
195x180x80mm
Weight: 7.0KG
Charging Current: 6 Amp
Rated Discharging Amperage: ≤10 Amps
Max Discharging Amperage: 2C
1X 6A Quick Charger
1X BMS
Specifications:
Voltage: 48 Volts
195x180x80mm
Weight: 7.0KG
