LI-ghtcycle
Hello everyone!
I have been out of the scene for a while, but I still maintain my father's E-Bike, and today it appears to have finally succumbed to his full throttle no pedal start style of "Bat out of Hell" type riding at least as much as you can with 36V of Li-Po! (I kid you not, he's nearly 70 and AVERAGES over 20 MPH on a 4 mile ride he does every morning, and tops out at about 26 MPH!!)
I used this motor always pedal start, never pushing it hard for about a year and then switched with my father for his 9 x 7 DD Amped Motor, and that motor is still happily being abused by a new owner and working well today, however, the rear geared motor is only a 350W motor, what do you expect right?
Well, here are the symptoms:
Electrical "grinding" noise at the motor for about 5 feet when he went to "launch" (he always has the pedal gearing in one of the highest gears) and heard the sound, and from there on, there has been no obvious problem, but no sound from the motor, so I suspect motor failure rather than the internal gears.
I have checked all the plugs, cleaned with WD-40, dried them with compressed air, and still nothing.
Are there any simple continuity tests or other simple tests barring having a second Amped Bikes controller to plug in to confirm the dead motor? Not really wanting to buy fancy diagnostic equipment, just hoping there might be a couple simple tests to confirm the soundness of the motor's windings?
Thanks!
Thanks!
