safe
1 GW
- Joined
- Dec 22, 2006
- Messages
- 5,681
fechter said:I've noticed a substantial loss in pep from lead acid batteries when the weather gets cold.
You seem to lose your peak current capacity as it gets cooler, but the overall energy capacity seems less affected, at least with older batteries like mine that may have been a year or two old before I even bought them since they were one of those "super discount" special offers.
Practical Adaptation
The way to adapt is to stop "short shifting" and instead scream the motor out all the time. This has the effect of keeping the rpms into the "post power peak" area that is also better in efficiency. I did a 12 mile ride and started at 13.0 volts and ended at 12.1 volts which is about as good as I ever did. My average speed was right around 24 mph, but my top speed was way down. Before I could sometimes squeeze out a 26 mph average on the fastest rides. So basically if you sacrifice acceleration and avoid the too tall gears you end up okay, the battery seems to behave better if it's never forced to go to it's current limit. If you stay within a lower current draining regime the battery can sustain it, but it seems like if you overdo it the recovery takes a while.
It's fine for cruising around... just don't try to set any new track records...
Oh my god... I'm starting to ride like Xyster... ahhhhhhhhhh...
![Shock :shock: :shock:](/sphere/data/assets/smilies/icon_eek.gif)
