Nice. Any concerns over having drilled holes there?My crazy idea for switches. Power, cruise control and street mode.
Not at all.Nice. Any concerns over having drilled holes there?
This stem is pretty thick so i have no worries about it breaking.The stem is a critical, highly stressed part. A failure would be catastrophic.
It looks like you used a quality stem.
If one is worried and OCD, one might drill holes under size and ream to final OD.
Otherwise: vaya con dios.
I saw GRIN was planning on making a version of this for 135mm dropouts as well
I saw it as well. It's a single speed. It was mounted on a cruiser type frame. But I can't find any reference to it on their social media. I must have seen it on the cruiser frame builder's social media but I can't find it.Woah, where did you see that?
I do but really starting to like the lighter bikeDo you miss the front suspension?
Wow, that's some great info! I was researching hard where to order some 32H 80mm 20 inch rims, but came up empty. Ended up having to order a 90mm from grin and let them do the wheel build for me. Probably for the best as I have never done a wheel build yet and don't need the stress right now in getting it wrong on such a high priced hub motor.Hard lesson on what rims will work with this motor being offset as much as it is. Started with a Mulefut 80 and not a chance to get even close to center. Had the brake side fully tensioned and the chain side finger tight and it was still not over far enough. Switched to a Alex Blizerk 70 and its better but still not perfect. After a bunch of searching i found a rim that will work good with almost an even tension on both sides. Bontrager Jackalope with offset spoke bed
Are you talking about this rim? Rim20_Fat90_32HWow, that's some great info! I was researching hard where to order some 32H 80mm 20 inch rims, but came up empty. Ended up having to order a 90mm from grin and let them do the wheel build for me. Probably for the best as I have never done a wheel build yet and don't need the stress right now in getting it wrong on such a high priced hub motor.
I'll google and see if that rm is available in an 80mm 20 incher. Thanks.
Looking forward to your progress this weekend.
Yes. That's what they're going to build for me over the next few days and send me. They said it would work.Are you talking about this rim? Rim20_Fat90_32H
Hmmm... Interesting info. I'm a complete noobie on this stuff for fat bikes. I was trusting grin that it will work.If so i can tell you that there is no way to get it centered between the dropouts unless your frame is offset where it wont matter. If the rear tire is not inline with the front you will have steering wobble
What frame do you have?Hmmm... Interesting info. I'm a complete noobie on this stuff for fat bikes. I was trusting grin that it will work.
Do I need to ask them to offset the wheel build to work or something? I will be using a 7 speed Shimano cassette. Do I need to send them a pic of my rear dropouts with some measurements? Or I just need a completely different sized rim or something?
They don't seem at all concerned about this. Which is why I didn't even know it could be an issue.
I can take a picture of my rear dropouts from the rear if that will help show the design/offset of my bike.
No worries at all man. All good. I appreciated you were being helpful. Thanks for the clarification and correction.View attachment 376097I didn't consider that you probably have a 170mm dropout and if so it will work just fine. I apologize for being an idiot.
