Ape_R said:
To sum it up I am in need of either a bike which can preferably reach 60mph top speed (I don't plan on riding that fast most of the time) and has 150 miles of range.
You're going to need a lot of battery for that kind of range, especially at typical motor-vehicle speeds (even in traffic), even if you are riding on completely flat paved streets with no winds. This is generally large and heavy, even using the most capacity-dense cells you can get.
If your terrain includes hills or slopes, and there are winds, power usage increases, and moreso with more weight.
If your route includes a lot of stop/start traffic, or even slowdown/accelerate traffic, power usage also increases.
You can look at some of the other threads in this section I've posted in for guides on how to determine power usage for your specific situation, and from there how to determine required battery size, and how much you should add to it for unexpected detours, headwinds, road conditions, etc., and how much more you should add to that for aging losses over the time you will still require the max range to be available.
While it is possible to build no-weld framework, it will likely require more design and probably testing of interconnects to be sure it will be as strong as needed, vs a good welded joint, based on my own experiences trying this method for heavy-cargo bike and trike frames and trailers. Even my earliest worst post-practice welds had generally better results than most of my no-weld designs.
I'm not an engineer of any kind, so that could just be my lack of knowledge/experience, but I'd venture that the same would apply to other non-engineers....
If you are on a severe budget restriction, and are certain you will never use it for anything but the one project
some of the HF welders that do fluxcore can also do MIG; the one I have can but I have only used it for fluxcore. Someday I'd like to get a bottle of gas and some solid wire to try MIG welding instead. HF used to send out some decent coupons in the junkmail flyer bundle, but they stopped not long after the plague started, and have never resumed them, here.
Much of my early builds have been done with a version of this
https://www.harborfreight.com/welding/welders/mig-flux-welders/flux-125-welder-63582.html
which often had a flyer coupon for $99. It works, but it isn't very good. I still use it for stuff around here that can't be moved (fences, etc) that I also can't run a 220 extension cord out to, but can run the 110 cord to.
My SB Cruiser trike and most other things done now are done with a version of this
It's significantly better than the one above, even as just a fluxcore welder; I'm sure it'd be better than that as MIG but never tried that yet.
The major problems with any of the HF welders I've tried so far is their feed mechanisms are not smooth, and can cause stuttering during the weld, which can screw things up.
They can be tweaked to work better, but they'll never be great.
