dennyt said:ZOMGVTEK - very nice! Can you elaborate on how you isolated the DC negative from the chassis? I picked up a few Dell DPS-500CB's (12V 41A) and I'm getting ready to assemble them in series. I like the idea of keeping the cases grounded and isolating the DC negative.
These supplies happen to be fairly well documented, but I just opened one up and its fairly obvious. The two screws closest to the DC side had pads that contact the case, and the AC ground comes in and goes right to the case. Clearly this would be an issue if you threw the supplies in series with a common ground. It happened to be fairly easy to just disconnect the DC ground, but removing the AC ground internally works fine. You would then need to physically isolate the cases if you went that route.
It just depends on your supply. Take a meter to the case and a the DC ground, start removing screws and lifting sections of the board until it goes open. You can just shove tape under the board and not put the screw in if you want. It all just depends on how the thing is designed. It might even have a single wire you can just cut.
