DRMousseau
After a year of planning, preps, research, and all,… I'm jus about to begin construction on a unique project bike and still have some need for opinions, considerations, and overlooked thoughts. Hope you're patient with the following overview,… otherwise, skip down to my current matter of consideration and needed opinions.
Personal background includes more than general history and basis of modified & custom motorcycles, electric golf cars, general bicycles, and more, both professionally and personally. But only a year or so with e-bikes,… my current 29er is based on an ordinary big box cruiser. Currently fitted with 1500W Leaf, basic 40A controller, 52V 11.5AH LunaCycle pack,… it's been great. All I had hoped for and more,.. VERY pleased and satisfied in my choice. That "more" though, HAS required some added extras,… Schwalbe Big Apples, new front wheel assy, some custom brackets and triple-tree fork to accommodate BB-7 disk brakes, with a few other minor added basics. This bike will be restored to it's basic for and sold while all added extras will mostly be transferred to new project.A brief rundown of NEW PROJECT,.… a 26" e-bike. A show quality Centennial 1917-2017 Commemorative, to "The Stealth Bomber"!!! From it's early aviation beginnings with The Curtis 1917 JN-4HB (also known as "The Jenny"), the 2-seater which was equipped with the more powerful engine of The Wright Company, the bicycle guys of aviation fame. The "B" model of the "H series" Jenny, designated "Bombing Trainer", and was also the first successful Dive-Bomber. Other JN-4H models included the "G", gunnery trainer, and the "M" of First Air Mail fame. THIS commemorative bike will feature a blend of old and new technology including a frame that reflects aviation's modern "stealth" designs and angles as well as being reminiscent of the early bi-plane and bicycle form as well as early JN-4H paint scheme. A permanent leather padded "co-pilot/passenger" seat, with permanent passenger foot-pegs is essential for legal requirements of bicycle passengers, and to maintain the early 2-seater history of the JN-4H. A facsimile of an early WWI/WWII era "BOMB" will be cradled in the frame, and will conceal the removable battery pack,… "H"idden "B"attery. A "cockpit" compartment under seat will house controller, key-switch, charger, etc. All wiring and most cabling will be in frame. A "mini-joystick" lever and exposed cable, will function the front 3-speed derailleur. Motor will be current 1500W Leaf with existing 52V battery pack,… slight more powerful than typical e-bikes, less than modern stealth bomber bikes of current popularity. Over all form is a rebel "chopper" design of open form rather than conventional compact form of traditional bikes. This allows more emphasis in past and present design forms in both, cycling and aviation.
While some choices MAY not be the very best, they were selected based primarily on form, simplicity, functionality, and purpose, with secondary considerations of reasonable economics. Bike WILL be displayed and featured in various local bike, motorcycle, auto, and air shows and participate in related activities. And of course,… it will be enjoyed daily on local paved surfaces.
Most builds of such sort, are designed and built around the power plant,… in this case, a direct drive hub-motor, the 1500W Leaf. Geared hubs and mid-drives were closely considered, but the Leaf won out on several criteria. THIS Leaf has a 135 axle, would much prefer a longer axle, but this will be accommodated in a unique bracketed dropout mounted in the full custom frame. The 26" rear tire AND rim is unusual!!! (seen below)
YES! That is a tubeless, automotive, compact "donut" spare!!! This T145 70R/17 is approx. 25.5" in overall diameter and about 6" wide,… it was selected for being closest to the standard 26" bicycle tire chosen for the front, and with considerations of motor. I want a TOUGH, "meaty", heavy duty rear tire, able to carry the excessive rear weight load (inc passenger) with no concerns what so ever!!! Also needed adequate axle height for reasonable seat and BB heights in the low slung frame design. Various "fat bike" tires and rims were considered as was some motorcycle rims and tires. Most ALL were VERY costly and prohibitive, and few provided any adaptability to my needs.
MY BIG ISSUE!!!!
I intend to cut and remove the center of this rim, and adapt it to my hub motor. Consider my needs,… heavy-duty strength, the hub will require a great offset in rim AND, a need to be stronger as an assembled unit than typical bicycle setup. I would actually prefer a solid "mag" type setup, but that's not practical in any way I can conceive. Next in preference, a lacing of motorcycle or automotive quality,… much different than a bicycle! Rim has no need for strength of lacing spokes,… only a need of solid, secure hub attachment. (Regarding offset,… a single speed rear freewheel will be used with 3spd chainrings.)
Your OPINIONS, THOUGHTS, CONSIDERATIONS and SUGGESTIONS regarding my issue!!!
Since rim is "blank",… it can be drilled in any needed pattern or manner. Spoke holes CAN NOT be reasonably dimpled. I have considered drilling hub to 72hole, without greatly affecting spoke flange strength, AND drilling rim in any needed pattern to best facilitate offset, hub flange dimensions, spoke angles and spoke strength in a single cross lacing. Heavy gauge bicycle spokes can be accommodated by hub. I WOULD PREFER to keep standard 36hole hub, and drill rim to facilitate a single cross lacing. I MAY consider other lacing patterns, but would like to reasonably match front rim lacing appearance. Again,… front wheel assy, is desired to be a pretty standard 36hole 26" bicycle setup. Front weight of bike should be no heavier than typical with long raked forks providing some "cushion" and any weight transfer during braking should not be excessive for quality front tire, hub, spoke, and rim assy.
SO,…. Should I maybe consider a strong straight lace 72hole on both front and rear??? What of "spoke line" in drilling rear rim??? Should I consider "cross lacing" of rear due to wide rim and narrow hub flange??? Since rim is EXTREAMLY small in diameter, should I consider a grouped pattern drilled into rear rim for better spoke angles??? Certainly needed if a single-cross lace is to be done in 36hole and likely in a 72hole. What will be my "strongest", most solid lace pattern for rear that I can match to front???
Other thoughts??? Other options I may have overlooked, not known, or maybe not considered????
MY BIG ISSUE!!!!
