Hey Guys,
I'm having problems with my amp hour meter (came with a 100A shunt) and was wondering if the following can cause such errors like I'm experiencing of 20-40% off in the amp numbers.
The shunt has 4 connections, two big ones and two small ones for the meter.
I have soldered another wire to one of the meter connections in order to pull a negative wire to power the meter screen.
Can that solder change the measuring somehow? if so, can it be by that much?
Also, I trippled checked and everything is installed correctly, but what would happen if the big wires that go through the shunt are reversed (flipping between the battery and load sides), what can happen then?
