I recently picked up a bikee recumbent bicycle with the intention of creating a long-distance electric bicycle. It seems to be a popular recumbent to convert to electric. Here's a pic.
I chose a recumbent because of the lower wind resistance and power demand and I'm using the highly efficient 9c motor on a 20inch rim (I'm modifying my bike's seat to reduce the frontal area to further reduce drag), and now I've ordered a semi-flexible solar panel kit that should be capable of 130 W and can be wired at 36volt, or can be configured lower (I haven't done the math, but I don't think I'll be able to get exactly between 24.6V-25.2volts for my battery without additional electronics). Here's the kit I ordered:
http://www.eco-worthy.com/catalog/product_info.php?products_id=267
I chose this one because it uses crystalline solar cells which are much more efficient than the thin-film variety (to get 130W required a ton of space for thinfilms) but it was also much lighter than the glass variety and because it's semiflexible, it should be durable to the strains of biking, but now I need to figure out how to hook it up on my bike. I'm guessing I'll probably either need to get a step-up or step-down buck converter (some sort of charger, probably), and it needs to constantly provide charging to the batteries while the batteries are being used by the electric bicycle.
Hmmm...
I'm just thinking of it.
Can I just hook these things up to my battery during use at 36 volts using a shottky, assuming my lipos are wired at 24V? I'm pretty sure I'll be using more power than my solar panels can provide, so I'm not really concerned about overcharging the batteries and I'm assuming the voltage output of the solar panels would decrease itself to match the voltage output at the battery. Then when I'm stopped, I could wire the solar panels up at 18V and plug in my lipo charger. Would that work? What if the power spontaneously decreases due to a passing cloud, would the Lipo charger just stop charging? I have a hobbycity lipo charger.
Thanks for any help! I have no experience with solar panels. ^_^
(The trip I'm planning on looks like it has about 80 miles in total, 40 miles one way, 40 miles the other, and I figure if the solar panels are providing 80watts power while the bike is consuming 150watts at 15 mph, it seems I should only need 140wh-200wh of battery one way and then 140wh-200wh the way back. And, I can reduce that further by pedalng though I want to minimize that - this bicycle seems to hurt my back. I'm not sure why, exactly, but I'm suspecting pedaling has something to do with it, along with the bike seat since I'm pressing my lower back against the bike seat. I can pedal on my upright bike and my back doesn't hurt at all. Since I'll be packing around 1000 watthours, and assuming I stopped in the area for 4+ hours, I could probably go 20 to 25 mph, though I might have to wire the batteries, and solar panels, upto 48v.)
Hmmm...
