Modbikemax said:
amberwolf said:
Keep in mind that typically a hollow axle isn't as strong as a solid one
Really? I would have thought the opposite is the case.
I'm going by things like this:
http://www.cyclingforums.com/t/366034/strength-of-solid-versus-hollow-axles
jtaylor@NOSPAM. said:
Recently therehave been a few posts which may confuse (or indeed
originate from) uneducated reader(s) concerning the strength of solid
versus hollow axles.
The strength of any particular cross-sectional shape can be described
by quantity called the section modulus, which is kind of a combination
of the amount of material and the distance away from the bending line
- usually taken as the centre - of the section.
If we take a typical rear axle the OD is pretty close to 0.4 inch. A
hollow axle has an ID of pretty close to 0.2 inch - giving a tube or
column with a wall thickness of almost 0.1 inch.
Using these numbers:
The solid axle will have a section modulus of 0.00627.
The hollow axle will have a section modulus of 0.00588
For front axles, which are around 0.35 OD, the numbers are:
Solid - 0.00435
Hollow - 0.00390
Now, of course, these figures mean that a solid axle is stronger.
There are other factors which affect the strength of axles, of course;
the choice of material, the heat treatment, the surface finish,
etcetera.
A particular effect which cannot be eliminated from hollow axles is
that of the roughness of the inside surface of the hole. Solid axles,
of course, do not have this, and so also do not suffer from the chance
that a crack may start at an irregularity on the inner surface. Cycle
axles of the highest prices (and, the buyer may sometimes presume, the
highest quality) are finished very well on the outside surface; but
the inside is a hidden quantity, difficult to finish and inspect.
In the real world of cycling, there are axles made from different
material and to different qualities. Of course it is possible to find
a particular hollow axle which may be stronger than another particular
solid axle - but to claim in abstract that a hollow axle is stronger
(or even no weaker than) than a solid one is clearly wrong.
It's not a lot of difference, probably, but there's some.
Also, since we are talking about other forces (twisting) on these motor axles than just the ones on regular bike axles, I expect there is a little more difference between them, but I woudln't have a clue to the math to find out.
I *would* say that I've seen more threads about axles that broke on the hollow side rather than the solid side, but even that isn't necessarily statistically significant, since I have no idea what percentage of people total with broken axles have even posted.
Anyway, the QR solves at least one problem with threaded/flatted axles, whether solid or not: Tight nuts.
Now that the little hamster in my brain has the squeaky wheel spinning, some other thoughts:
With the QR, it's a lot easier to get the right tension to tighten things up correctly than it is with nuts, and they are a lot less likely in my experience to work their way loose, at least from typical bicycle forces.
Since I expect there are a lot more *dropout* failures from twisting axles than there are from axles that actually broke from being hollow, it probably means QR axles, hollow or not, could be a much better solution even for higher powered motors.
As long as you don't tighten things so far that you snap the QR skewer from tension, it ought to work ok.
Now, another thought:
http://www.bikeforums.net/bicycle-mechanics/228399-solid-axle-stronger.html#post3053106
Someone brings up another point:
moxfyre said:
With a solid axle, the tightening of the axle nuts causes the axle to stretch slightly, whereas with a QR axle, the tightening of the QR causes the dropouts to press against the locknuts, causing the axle to compress slightly. Apparently, tensioning the axle reduces the strength of the axle a bit, while compressing it doesn't have that effect...
which is partly countered here:
http://www.bikeforums.net/bicycle-mechanics/228399-solid-axle-stronger.html#post3053440
TallRider said:
A solid axle does not actually mean that the axle is under tension when the bolts are tightened down. The only part that's under tension is the part of the axle between the locknut and the bolt - basically across the width of the frame's rear dropout, and then a little bit extra on each side as the force on the locknuts and bolts is distributed over more than one thread. The compression/tension on most of the length of a solid axle is effectively neutral.
A q/r hollow axle is under compression, however, when the q/r is tightened. This has ramifications for adjusting the bearings in q/r vs. solid-axle hubs, because the q/r axle compresses when the q/r is tightened, and thus tightens against the bearings, so must be adjusted with some play left in the bearings when the axle is not under compression.
Given that a solid axle is not under compression or tension, and a q/r axle is under compression, I'm dubious as to whether this makes the q/r hollow axle stronger.
However, it is true that a solid axle isn't much stronger than a hollow axle on the basis of its being solid vs. hollow. A rod's resistance to bending is proportional (and maybe quadratically proportional) to the diameter of the rod, so basically the material further from the center of the rod matters a lot more than the material at the center of the rod. So, a rod's being hollow (and missing material at the center of the rod) doesn't make much difference.
That discussion continues off and on thru the rest of the thread.
