ZapPat
methods said:Regen implies back to the battery in my mind.Doctorbass said:Hey... wait a minute...!..
Are we talking about regen THAT RETURN THE POWER TO THE BATTERY OR REGEN THAT SHORT THE MOTOR TO DISSIPATE THE ENERGY INTO IT IN HEAT ???
Cause if the Methods's motor heat so much, i would guess that it's because of the controller would just short every phases instead of conducting to put back the energy into the cells? right?
Doc
Otherwise I would call it a crow-bar brake
Regen currents on the motor that gets hot (mind you this is a different setup that what we are talking about here) are around 20A @ 100V so 2KW regen. No motor can regenerate 2KW without creating heat regardless of how efficient the firmware is.
-methods
OK, I see you have a kelly controller (not a golden motors or similar), so I would suspect they must use some good regen firmware code - not something that's hacked together. So yes I agree that you will generate heat when doing 2kW regen for sure... but how much more than while just driving 2kW into the motor? What regen percentage do you get on one of your runs that makes the motor so hot? I could swear I saw someone post a graph of motor amps+volts+temp vs time, and we saw the temp go up fast during the regen time (going downhill after going up). But I didn't see the same graph done while just coasting back down (no regen) to compare to.methods said:I have done away with regen on my "real" ebike.
Since I disabled regen my motor temps have been much lower. I dont have definitive numbers but with regen the motor got so hot that I could smell it on hard rides. Now it only gets hot enough to burn my hand![]()
-methods
A quick question if you don't mind: How do you like kelly's regen implementation? After using it for a while, what do you find are it's good and bad points?
