STOP THE PRESS -> CA can be used for THRUST CONTROL and more
methods said:
Only an extreme gangster can spin the rear wheel :)
I can only spin mine if I'm not on the bike, on loose pavement or dirt. However, in the right gear I can get it to slip if I gun the throttle when turning on same loose pavement or dirt, right before it starts slipping the chain due to insufficient derailer tension to hold it on.
Once I build a direct-to-rear hub drive without a derailer, using something like Thud's 2-speed dog-clutch, I think I could probably spin the wheel at least with a fresh full charge on there, at 36V. At 48V I am almost certain I could do it. :)
And that with just a "650W" wheelchair/powerchair motor and gearbox. ;)
Now, getting it to spin on sticky new pavement; that's another story. :lol:
Speaking of spinning wheels, now I'll be able to do that easily with my brand-spankin' new hub motor...
...just as soon as I connect the batteries and there's a heavy snowfall... :)
Definitely looking forward to trying out the PI control features on the CA!
I liked the downhill video.
-methods
In the "downhill" video where he is leaning into corner, the ride is a Steintrike. There are only a handful of recumbent trikes out there currently with front suspension, and Steintrike is one of them. This should make the leaning, and the stability, better at higher speeds.
Regarding the temperature control as posted earlier, i found this little thermocouple board that outputs 0 -5v =to 0 to 500deg.
Perhaps it could be tuned to a narrower range.
Or hook up to a panel meter for a tidy little thermometer.
http://reprapdoc.voodoo.co.nz/bin/view/Main/Thermocouple_Sensor_1_0
Well, the chip itself appears to be limited to 10mV per degree C, if I read the spec sheet correctly, so it has a fixed range that depends on your supply voltage. However, you could easily add an op-amp scaling and offset circuit, so that it scales that output voltage up quite a lot, forcing it to go from 0V to 5V for say, 200C instead. Or less, if you like.
